Author Topic: Unable to flash ESP32-WROOM-32D through UART  (Read 1948 times)
Offline aiq25Topic starter
« on: January 19, 2022, 10:55:19 pm »
Hi guys. I'm having a strange issue flashing an ESP32-WROOM-32D module using UART (using an CH340C but I have tried it with a CP2104 module as well with no luck).
Upon restart of the ESP32, it communicates data via UART, so I think it is working nominally and the TX and RX lines are working.
When I try to program by putting it into bootloader mode (hold IO0 LOW then doing a RESET), I get the "waiting for download" message from ESP32 but when I try to program, Arduino can never connect to the module.
I have this on a breakout board from Amazon with 22uF capacitor on the 3.3V on the module and a 100nF from EN (RESET) to GND.
Attached are the messages I get from the ESP32 module.
I have also tied IO2 externally with a 10kOhm resistor to ground.
Does anyone have any experience with this?
I have tried to use different baud rates as well but no luck connecting during the flash process.
I'm using the latest Arduino IDE with the latest ESP32 cores.
Offline UberBen
Re: Unable to flash ESP32-WROOM-32D through UART
« Reply #1 on: January 20, 2022, 07:11:08 pm »
I picked the NodeMCU-32S in the IDE.  To program, I hold the IO0 button from power up until flashing is done.  Letting go of the IO0 button caused it to fail.
I have this board: https://www.amazon.com/gp/product/B09J95SMG7
« Last Edit: January 20, 2022, 07:13:55 pm by UberBen »
The following users thanked this post: aiq25
« Reply #2 on: January 25, 2022, 08:05:07 pm »
I tried another board and it worked. I guess the first breakout board I was working with had some issue with the "RX" pin.
Offline mazurov
« Reply #3 on: January 25, 2022, 09:29:55 pm »
Related - if anyone is struggling with automatic bootloader entry from non-esp-idf toolchain the correct timing is on the screenshots. Details here: https://owenduffy.net/blog/?p=21574
With sufficient thrust, pigs fly just fine - RFC1925
