Hi guys. I'm having a strange issue flashing an ESP32-WROOM-32D module using UART (using an CH340C but I have tried it with a CP2104 module as well with no luck).
Upon restart of the ESP32, it communicates data via UART, so I think it is working nominally and the TX and RX lines are working.
When I try to program by putting it into bootloader mode (hold IO0 LOW then doing a RESET), I get the "waiting for download" message from ESP32 but when I try to program, Arduino can never connect to the module.
I have this on a breakout board from Amazon with 22uF capacitor on the 3.3V on the module and a 100nF from EN (RESET) to GND.
Attached are the messages I get from the ESP32 module.
I have also tied IO2 externally with a 10kOhm resistor to ground.
Does anyone have any experience with this?
I have tried to use different baud rates as well but no luck connecting during the flash process.
I'm using the latest Arduino IDE with the latest ESP32 cores.
