Author Topic: Updated Pi Zero..  (Read 12573 times)
Offline CJay
Re: Updated Pi Zero..
« Reply #25 on: May 27, 2016, 06:04:22 am »
Amazon have a decent one for under $2.
But then I have to order $48 of other stuff to get free shipping :)
I bought the adapters I use with mine for about £1 inc. shipping from eBay, recently one of the local £bargain stores have started selling them, might be worth checking a diollar store if you have one nearby.
Offline eugenenine
« Reply #26 on: May 27, 2016, 11:17:55 am »
It was more of a rant about using the odd size than not being able to get one.  The rest of the world uses regular HDMI or micro so why make a new product using the odd size no one else uses.  Unless maybe they got a bunch of miniHDMI ports on clearance for really cheap :)
Offline NiHaoMike
    • Facebook Page
« Reply #27 on: May 29, 2016, 06:27:44 am »
I have a pogoplug, it's a POS...ungodly slow with next to zero RAM, unusable for most things you might want to do with it.  I couldn't even rsync some files to it without setting up a damn swap drive.  It went in the closet within about 15 minutes of setting it up.
As far as SBCs go, I'm a big fan of the ODROID XU4 due to its raw compute power, USB 3, and gigabit ethernet, as well as the Dragonboard 410c for its awesome mix of high speed and low power and ease of integrating into other devices.
Have you tried a distro specifically designed for small embedded systems like OpenWRT? 128MB of RAM is actually a lot for an OpenWRT device. I have a Pogoplug (modded with a second Gigabit NIC) running OpenWRT as my main router and barely even 1/4 of the RAM is in use despite being on a rather busy network.
Arch is indeed a bit resource heavy but even that has its uses. I have another Pogoplug running Arch that supervises an "experimental" altcoin mining machine. All it does is run a Python script to regularly check if the miner is working properly and restart it if it isn't. A bit of a kludge but it's the difference between a setup that I can just leave under my desk mining altcoins and a miner that needs too much attention to be worth running.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline eugenenine
« Reply #28 on: May 30, 2016, 09:28:06 pm »
Thats why Slackware is going on mine, it will run on just about anything.
Offline CJay
« Reply #29 on: May 31, 2016, 01:56:11 pm »
Fair point, I have a couple of Android tablets that have the smaller connector and the rest of my 'stuff' uses regular HDMI so it was a bit annoying to find I had to buy yet another adapter to use a 'standard' connector  but as someone more famous than I once said, the nice thing about standards is there are so many to choose from.
