Author Topic: using communication hardware on the ATMega  (Read 9222 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: July 02, 2014, 08:38:02 am »
I'm designing a project where ultimately I want 2 chips to be able to communicate with each other and/or a PC.
Should I use RS232 / serial interfaces ? or is there something better ? I've never done communication protocols before.
I'll start reading the datasheet but ultimately I have no idea yet of how much is hardware based and how down and dirty i need to get to transmit and receive a piece of information.
Offline Codemonkey
Re: using communication hardware on the ATMega
« Reply #1 on: July 02, 2014, 08:55:12 am »
How far apart are the devices going to be ?
If the're located more than a few inches, using the UART will likely be the easiest. No need to bother with RS232 level shifting, just get one of the FTDI USB-TTL serial cables for interfacing to the PC (many of which don't even come with a serial RS232 port these days).
  • Global Moderator
« Reply #2 on: July 02, 2014, 09:16:17 am »
The actual MCU's would be close so no distance problems, I'd use an FTDI adapter yes for any PC communication. Can serial communication connect to more than one device ? I guessing not. Is there the equivalent of an FTDI for other protocols like SPI ?
Offline Codemonkey
« Reply #3 on: July 02, 2014, 09:24:09 am »
When you say close, how close ? On the same board ?
I think there is a way of using some of the FTDI chips in a SPI mode, but I have not done so my self.
Multidrop comms with a UART can be done though, RS485 for example. Ideally you need to assign one device as a master that then polls the other devices since it is a half duplex protocol.
So, if you have device A (master) and B, C, D etc which are slaves, you would need to create a protocol whereby the slaves all place the transceiver device in receive mode (RS485 devices have a direction pin which you must control), and then the master sends an address byte followed by the data and then goes into receive mode. The slave with the matching address then receives the message, processes it and if required places its transceiver device in transmit mode and sends a reply addressed to the master.
  • Global Moderator
« Reply #4 on: July 02, 2014, 09:28:05 am »
Do atmega's do RS485 ? Yes the two MCU's are on the same board.
Offline Rerouter
« Reply #5 on: July 02, 2014, 09:28:30 am »
if you want either to be able to talk directly over the same cable to the computer, you could have an RX/TX pair going between the 2 micros, and use some intermediary logic to swap one micros TX/RX lines with the computer at a time so it can talk directly with it, (analog switch with 2 enable pins and possibly and Xor Gate)
Offline Codemonkey
« Reply #6 on: July 02, 2014, 09:39:54 am »
1st thing you need to understand is that RS232 and RS485 are only electrical specifications for the voltages / signaling method. The data itself comes from the the UART (the bit in the microcontroller) and is just known as asynchronous serial data.
If you want to implement RS232 or RS485, you buy a transceiver device which translates the TTL/CMOS signals from the micro to the appropriate voltages for RS232/485.
The ATMega won't "do RS485", its up to you to add the transceiver to the UART pins of the micro.
However, since your micros are on the same board, its a bit overkill to add RS485 for a few inches at the most. Does your microcontroller have more than one UART ? If so, use one to communicate with the PC, and the other to link the 2 micro's. If not, you might be better off using I2C or SPI for the link between the micro's and reserve the UART for the PC connection.
Maybe if you could describe a bit more what you're trying to build and what the devices will be doing that would help.
Online nctnico
« Reply #7 on: July 02, 2014, 10:05:40 am »
If you are using two MCUs I strongly suggest you choose a different MCU which can do all the work by itself. Getting a communication protocol to work reliably can be extremely tricky. You need to take care of things like missing a message, messages with an error. What do you do in case of a time-out? What if the watch-dog gets triggered on one MCU and it resets?
Needing two MCUs suggest that these will be busy doing something so you get a lot of timing constraints on handling the communication. I have seen many novices fail when trying to stick to the MCU they know by using multiples MCUs! Please don't dig your own grave...
« Last Edit: July 02, 2014, 10:07:44 am by nctnico »
  • Global Moderator
« Reply #8 on: July 02, 2014, 10:16:42 am »
I am using two MCU's to provide redundancy in case of failure not for multitasking. At the moment I am using an ATMega328 family chip, I'll see how big my code is and probably be able to go down to a mega48 or 88. I'm not certain yet of actually doing serial coms between them, I might just use a pin outputting a fixed signal to act as a heartbeat that the other chip can verify, then I do have the single serial interface free to do PC communication but that is a later development and will mean me looking into how i can program variables from a PC over the serial interface and read back information for diagnostics. At the moment I'm trying to roughly work out what resources i need to ensure I have the right chip and use the right pins without creating conflicts.
Online nctnico
« Reply #9 on: July 02, 2014, 10:20:42 am »
For communicating with a PC the easiest way is to implement a command line interpreter. That way you can test/demonstrate the communication with any terminal emulation program (like Hyperterminal).
  • Global Moderator
« Reply #10 on: July 02, 2014, 10:23:21 am »
uh, now your running ahead of me ;) what I'd hope is that the pc can receive data from the chip about selected working conditions but also send data back to modify variables that I gather will have to be stored on the eeprom ? or can I alter the main flash ?
Offline Psi
« Reply #11 on: July 02, 2014, 10:26:21 am »
All AVRs (that i know of) have "Multi-processor Communication Mode" which is a hardware feature so the MCU can ignore serial data not intended for it when there are many serial devices on the same bus.
It uses an extra bit to indicate if a frame is an "address frame" or not. If the address matches the MCU it will receive all bytes until a new address frame comes along.
I've never actually used this feature but it looks quite useful for multi-node communications.
So to answer your question yes, you can have multiple serial devices connected together.
There's a few different ways to do it though....
You can pass the data along serially in a chain and not have the issues of collision (two devices transmitting at once). If a mcu receives info it checks the address part of the data packet and does whatever action is needed, otherwise it re-transmits it to the next device.
(Note: This mode can not work with Multi-processor Communication Mode because you need to receive the data to re-transmit it. You need to write your own address info into your protocol)
|--TX PC RX-----TX mcuB RX-----TX mcuC RX -|
or, for simple one-way coms you can just connect one TX to multiple RX
PC  TX--|----- RX mcuB
            |----- RX mcuC
            |----- RX mcuD
or, combine TX/RX into a bidirectional line and connect all MCUs together with a single 2 wire bus.
You have to make sure your protocol wont transmit on two devices at once.  eg, you can pass a token around or have a master that polls slaves to see if they have anything to say. Or have each MCU talk at a specific time which is different between all mcus.
This method is what Multi-processor Communication Mode was intended for. You can have 100's of devices on the bus and not keep wasting interrupt/cpu time on every mcu checking all messages for some data only intended for one mcu.
TX&RX   TX&RX   TX&RX
PC         MCUB    MCUC
There maybe other ways too.
« Last Edit: July 02, 2014, 10:44:20 am by Psi »
Online nctnico
« Reply #12 on: July 02, 2014, 10:47:57 am »
With a command line interpreter you can create commands to do that. You could create a command like 'write_setting 1234' which will then alter a setting somewhere in flash or eeprom.
  • Global Moderator
« Reply #13 on: July 02, 2014, 10:49:48 am »
so presumably I have some code in my MCU that scans through what it is receiving from the PC and when it recognizes a code it carries out instructions.
Offline Psi
« Reply #14 on: July 02, 2014, 10:59:43 am »
Yes, you decide on a packet length you want. (or you can code a variable packet length protocol if you want something a bit more robust for large data transfers)
It's easy/fast to use a fixed length and have a hardcoded start of packet marker.
This is really crude, but you might have a 8 byte frame like this..
STR,a,cd
Where
STR = 3 byte start of packet marker
a = 1 address byte (so 255 possible nodes on the bus)
c = 1 command byte
d = 1 data/payload byte
, = separator (more on this later)
You would start filling up an array when you detect the letters STR in sequence. After 8 bytes you run some packet handling code to do whatever events you want based on the a,c,d data.
You can ignore the packet if the address doesn't match the address of the mcu checking it. etc..
Use a C switch statement on the command byte. That would give you 255 possible commands and each could carry 1 byte of info.
eg, command=45 (says flash LED1)  payload=10 (says flash this led 10 times)
The reason i included the 2 commas was so you cannot physically have a STR in the data/address section, this is crude but means you can never get out of sync (where STR inside the packet gets interpreted as the start of a packet).
You could add a checksum as well, a simple XOR of all the bytes and attach the result to the end of the packet.
If, when receiving a packet, it doesn't match ignore the packet (it's corrupt).
It gets more complex if you need a protocol that ensures a packet gets to the destination without being corrupted.
You then need to code an packet acknowledge and resend system etc..
« Last Edit: July 02, 2014, 12:34:18 pm by Psi »
Offline bwat
    • My website
« Reply #15 on: July 02, 2014, 11:01:05 am »
Yes, the command line interpreter interface is almost always a winning design for an interface. In fact designing in terms of interpreters is quite nifty and often structurally very "clean". Anybody in any doubt should read Hal Abelson's foreward to the book "Essentials of Programming Languages, 2nd Edition". You can read it here http://books.google.se/books?id=GtPoyremy4EC&printsec=frontcover&hl=sv&source=gbs_ge_summary_r&cad=0#v=onepage&q&f=false
"Who said that you should improve programming skills only at the workplace? Is the workplace even suitable for cultural improvement of any kind?" - Christophe Thibaut
"People who are really serious about software should make their own hardware." - Alan Kay
Online nctnico
« Reply #16 on: July 02, 2014, 12:19:26 pm »
STR,a,cd
Where
c = 1 command byte
You would start filling up an array when you detect the letters STR in sequence. After 8 bytes you run some packet handling code to do whatever events you want based on the xx data value.
Don't go this route. It makes debugging the communication with a PC much harder because you have no way to sit in between the PC and the microcontroller. Besides that the communication is always limited to the maximum packet length. It is much easier to fill a buffer with incoming characters and look if it is a command when a carriage return and/or linefeed comes along.
Offline Psi
« Reply #17 on: July 02, 2014, 12:26:43 pm »
There are advantages both ways.
If you go the command line interpreter way you have to deal with encoding/decoding numbers between multiple bytes of ascii and a byte/word variable.
eg, if you want to send the number 123 you have to encode that to 3 byte ascii "1" "2" "3". Send it, then decode that back into a number on the mcu at the other end.
Where as, if you have a packet system, you just send one byte.. the ascii character 123 with no translation needed.
Yes, you can use printf to convert things with one function, but it's not exactly the fastest of methods. (it generates a lot of code behind the scenes)
It really depends what sort of coms you want and the speed you need.
If its at the human interaction level or a fast stream of data.
Command line interpreters aren't intended for fast MCU->MCU comms
But yeah, i totally agree about debugging being easier with CLI
« Last Edit: July 02, 2014, 12:46:27 pm by Psi »
Offline bwat
    • My website
« Reply #18 on: July 02, 2014, 12:43:00 pm »
Which eliminates any potential issues to do with different endianness.
Exactly, and until we've seen a specification we're all just revealing our technical prejudices - which is fun.
  • Global Moderator
« Reply #19 on: July 02, 2014, 12:57:39 pm »
Well it's all mostly academic at the moment but something I'm likely to be asked to do sooner or later, basically read data being spat out of the serial port by the program with the ability to receive commands that alter variables for in the field tweaking.
Offline Psi
« Reply #20 on: July 02, 2014, 01:19:11 pm »
Your better off with a CLI then.
It's good for easy in-field changing of parameters, you can change things with any serial terminal app on any PC.
  • Global Moderator
« Reply #21 on: July 02, 2014, 01:20:06 pm »
CLI ?
Offline Psi
« Reply #22 on: July 02, 2014, 01:20:29 pm »
Store the serial data into an array up until a carriage return/LF then decode the array text to perform a function.
Then write code to understand a fixed number of keywords, each keyword denotes what follows it.
eg
SET EEPROM 56 234
Could be set eeprom address 56 to 234
or
ENABLE MY_FEATURE
DISABLE MY_FEATURE
QUERY MY_FEATURE    (this would return word enabled or disabled)
« Last Edit: July 02, 2014, 01:27:46 pm by Psi »
Online nctnico
« Reply #23 on: July 02, 2014, 01:43:47 pm »
 ;) Please don't allow to set eeprom values externally using a fixed address. Whenever you need to change the layout of the eeprom the PC application will break also. It also takes careful documentation of the eeprom layout. A couple of years ago I had to re-implement something like that and it was a total nightmare because the documentation wasn't up to date and the software wasn't very clear on what a value meant.
Offline Kremmen
« Reply #24 on: July 02, 2014, 08:08:43 pm »
+1 to this strategy.
You can use SPI in a master/slave configuration between the 2 processors and there it would be entirely practical to implement a frame based message format. A simple command+ optional data from master to slave, and simple response + optional data back. Just be aware of the nature of SPI so that you design a proper message header structure. Say you poll the slave and it responds with e.g. an 8 byte payload in the response data unit. The master must send the query command followed by a sufficient number of NOP frames to collect all the incoming response bytes, because the transfers are always bidirectional. (NOP = no operation). I have done a lot of these over the years so i can help if you want me to.
For the human interface by all means do use UART and CLI. The proper way to do it is already laid out in previous messages. Here you need to implement the command parser and ASCII-to-xxx conversion routines. Also a very good idea would be to implement a simple configuration parameter setup support that can output a list of parameter names and values. I have written systems where you have parameter values stored in EEPROM, minimum and maximum values in flash (program code) as well as the parameter cleartext name in flash. Outputing a simple numbered list with parameter name, curent value and min, max permited values is then simple. And you can set the values by referring to them by number instead of name (easier parser).
Also i have had good luck with RS485 (or i guess it is properly RS422 as it is not party-line) implemented so that the MCU board has a native RS485 interface and the PC end has a simple RS485/RS232 converter. Not strictly necessary on short distances but the only thing that works if you are say half a km away.
Nothing sings like a kilovolt.
Dr W. Bishop
