Hi guys,
I've been trying to learn verilog lately, and my latest project is to build a serial port echo device. I'm a bit stuck working out how to proceed to the next stage of my design.
I've tested both RX and TX modules separately and they work just fine (I'm using the ones from
here). I am having trouble putting together a one-shot system that will trigger the data transmit. Basically, RxD_data_ready is high when the module is not receiving data, so I'd like to pulse the transmit line. However, every time I try to implement a flag like has_sent_data, I get multiple driver errors. I understand why these are there, but I don't really know how to get around them. Can anyone give me a hint?
My current code is attached (snipped a little to keep it short):
wire ready_to_read = rxd & ~txd_busy;
async_receiver asr(.clk(clk), .RxD_data_ready(rxd), .RxD_data(rxd_data), .RxD(avr_tx));
async_transmitter ast(.clk(clk), .TxD_start(txd_start), .TxD_data(led), .TxD(avr_rx), .TxD_busy(txd_busy));
always @(ready_to_read)
begin
led <= rxd_data;
if (has_sent == 0)
begin
has_sent <= 1'b1; // this is the multiple driver problem
txd_start <= 1'b1;
end
end
always @(posedge clk)
begin
if (current_data != rxd_data)
begin
has_sent <= 1'b0; // this is the multiple driver problem
current_data <= rxd_data;
end
end
