Author Topic: CRC DMA PIC32  (Read 5299 times)
Offline MilanTopic starter
  • Country: cs
    • CNC MASINE
CRC DMA PIC32
« on: April 28, 2014, 12:45:02 am »
Hello,
is this right way to calculate CRC 16?
Calculation results on PIC and PC are not same  |O
extern BYTE Buffer[5000];
unsigned int DmaDoCrcExample(void)
       unsigned int hwCrc;
       int chn=2;
       DmaTxferRes res;
       mCrcConfigure(0x11021, 16, 0xffff);
       res = DmaChnMemCrc(&hwCrc, Buffer, sizeof(Buffer), chn, DMA_CHN_PRI2);
              if(res!=DMA_TXFER_OK)
                     return 0;   // DMA calculation failed
       return hwCrc;
Milan
skype: mladenovic.milan.kg
www.cncmasine.com
The greatest enemy of knowledge is not ignorance,it is the illusion of knowledge.
Offline miguelvp
Re: CRC DMA PIC32
« Reply #1 on: April 28, 2014, 01:44:24 am »
From another post I replied a long ago:
All you want to know about CRC algorithms with many different implementations and approaches:
http://www.csm.ornl.gov/~dunigan/crc.html
Another link of someone's implementation for embedded systems based on that paper linked above:
http://www.barrgroup.com/Embedded-Systems/How-To/CRC-Calculation-C-Code
Offline abyrvalg
Re: CRC DMA PIC32
« Reply #2 on: April 28, 2014, 10:53:43 am »
Check that following things in PC code match your PIC setup: polynomial (there are other possibilities than 0x1021), initial value (some code uses 0, some 0xFFFF), final inversion - any difference in these things will produce different results.
Offline miguelvp
Re: CRC DMA PIC32
« Reply #3 on: April 28, 2014, 03:39:28 pm »
aha! You found it!
Btw values for CRC CCITT is 0x1021 for CRC-16 is 0x8005
  • Country: cs
    • CNC MASINE
Re: CRC DMA PIC32
« Reply #4 on: April 28, 2014, 06:55:05 pm »
@miguelvp
@abyrvalg
Thanks for help.
Best Regards
Milan
« Last Edit: April 28, 2014, 07:28:19 pm by Milan »
www.cncmasine.com
  • Country: cs
    • CNC MASINE
Re: CRC DMA PIC32
« Reply #5 on: April 28, 2014, 08:36:39 pm »
After two days I decided to stop trying to make HW CRC working.
I decide to use SW CRC on both sides, It is not efficient but it works.
If someone have  idea how to set up HW CRC I will be thankful.
Best Regards
Milan
UINT16 Calc_CRC_C_ARC(BYTE *Buff, UINT16 Len)
   int i = 0;
   UINT16 crc = 0xFFFF;
   UINT counter = 0;
   UINT16 polynomial = 0xA001;
                  for(counter=0; counter<Len; counter++)
                        for (i = 0; i < 8; i++)
                              BIT bit = ((Buff[counter] >> (7 - i) & 1) == 1);
                              BIT c15 = ((crc >> 15 & 1) == 1);
                              crc <<= 1;
                              if (c15 ^ bit) crc ^= polynomial;
                  crc &= 0xffff;
                  return crc;
www.cncmasine.com
Offline abyrvalg
Re: CRC DMA PIC32
« Reply #6 on: April 29, 2014, 10:01:38 am »
Milan, can you post some sample data? Input buffer contents and hw crc result. I can try guessing the parameters for PC side code.
For sw way there is more efficient table-based approach that works on bytes instead of bits. See http://lxr.free-electrons.com/source/include/linux/crc16.h http://lxr.free-electrons.com/source/lib/crc16.c
That table is for 8005 (IBM) polynomial, but it's easy to find 1021 (HDLC) version.
