Author Topic: Vintage G-Tek Model 9000 EPROM Programmer - PGMX Software???  (Read 321 times)
Offline setelec
« on: September 28, 2019, 04:02:44 pm »
Hi All,
My apologies if this post is in the wrong forum. :-// I looked long and hard trying to figure out where to post it so please forgive me. :)
I acquired a vintage G-Tek Model 9000 EPROM Programmer some time ago and I would like to obtain the (MS-DOS based) software for it (PGMX).
This programmer was built in the late '80's/early '90's and interfaces with a PC via an RS-232 serial (COM) port. Unfortunately, G-Tek Inc. was decimated back in 2005 by Hurricane Katrina. Although a web-site still remains (www.gtek.com), the hyperlink to the PGMX software no longer works. I have attempted to contact G-Tek Support and they will try and find the old program files but there is no guarantee of success.
I am hoping that someone might still have/use one of these old EPROM programmers and could please help me out with a copy (archive) of the software.
I would like to get this programmer going as many of the newer budget programmers (like XGecu TL866ii Plus, etc.) don't support the higher VPP voltages (21V / 25V) of the older EPROMs.
Thanks heaps,
Shane,
Offline 1Ghz
  • Country: kr
The following users thanked this post: setelec
Offline james_s
Re: Vintage G-Tek Model 9000 EPROM Programmer - PGMX Software???
« Reply #2 on: September 28, 2019, 10:26:10 pm »
Apparently this was as good a place to ask. I was going to suggest asking on one of the classic arcade collector forums since vintage arcade machines use a lot of old EPROMs and bipolar PROMs but it looks like you got what you needed.
Offline setelec
« Reply #3 on: September 30, 2019, 10:32:25 am »
Here you are :)
https://web.archive.org/web/20150210134353/http://017b236.netsolhost.com/ftpfiles/pgmx946.exe
Thank you so much 1GHz!  :)
Unfortunately, I can't get that file to run. It is not a self-extracting archive, but rather an executable file.
I presume that the pgmx946.exe file that was originally referenced on the G-Tek website (www.gtek.com) was an archive, as the PGMX package should contain multiple files.
I really appreciate all of your help and efforts! :-)
With Best Regards,
Shane,
« Last Edit: September 30, 2019, 12:09:29 pm by setelec »
Offline setelec
« Reply #4 on: September 30, 2019, 10:43:06 am »
Thanks for the response and suggestions James!  :)
Unfortunately, the file that 1GHz linked to (thanks anyway 1GHz!) is not an archive of the PGMX software.
Your suggestion to try a vintage arcade machine collectors' forum is a great one. Thanks!  :) I'll see what I can find. I'm not holding out much hope, however. I am rather amazed how little a trusty Google search turns up on the G-Tek programmer...  |O
Thanks again!  :)
Shane,
« Last Edit: September 30, 2019, 12:10:36 pm by setelec »
Offline setelec
« Reply #5 on: September 30, 2019, 11:04:30 am »
Here you are :)
UPDATE:
You are absolutely awesome, 1GHz!!!!  :clap:
Trawling back to 5th October 2011 on web.archive.org, I managed to download the full archive:-
http://web.archive.org/web/20111005174959/http://017b236.netsolhost.com/ftpfiles/pgmx946.exe
This contains all of the files that are needed!
I cannot thank you enough!  :)  :clap: :)  :clap: :)
With Very Best Regards,
Shane,
« Last Edit: September 30, 2019, 12:12:16 pm by setelec »
