Author Topic: Critical Flaws Found in Amazon FreeRTOS IoT Operating System  (Read 3324 times)
Offline diyaudioTopic starter
« on: October 22, 2018, 05:08:33 pm »
A security researcher at Zimperium Security Labs (zLabs), discovered a total of 13 vulnerabilities in FreeRTOS's TCP/IP stack that also affect its variants maintained by Amazon and WHIS.
https://thehackernews.com/2018/10/amazon-freertos-iot-os.html?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+TheHackersNews+%28The+Hackers+News+-+Security+Blog%29&_m=3n.009a.1856.ch0ao075h1.151u
The following users thanked this post: chickenHeadKnob, SiliconWizard
Offline nomadd
Re: Critical Flaws Found in Amazon FreeRTOS IoT Operating System
« Reply #1 on: October 23, 2018, 05:34:34 pm »
..and already patched.
Whole-story always better, although less dramatic, than a half-story. :)
The following users thanked this post: mrpackethead, donotdespisethesnake
Offline Sal Ammoniac
« Reply #2 on: October 23, 2018, 05:50:02 pm »
That's good news, but I wonder how many unpatched, vulnerable devices are out there? Most people don't bother to update FW on the types of devices that typically use FreeRTOS.
"That's not even wrong" -- Wolfgang Pauli
Offline richardman
« Reply #3 on: October 23, 2018, 10:37:00 pm »
Yup, this could be problems for years to come... especially after the researchers release the details.
This is a tough problem that will only get worse when there are more and more IoT devices out there.
// richard http://imagecraft.com/
JumpStart C++ for Cortex (compiler/IDE/debugger): the fastest easiest way to get productive on Cortex-M.
Smart.IO: phone App for embedded systems with no app or wireless coding
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #4 on: October 24, 2018, 03:11:27 pm »
Most of which don't even run a well tested (RT)OS...
 :palm:
Wrong code should not compile!
Offline westfw
« Reply #5 on: October 25, 2018, 12:00:27 am »
To be honest, I don't know how important these are in the sort of device that is likely to be running FreeRTOS.
"Remote code execution" would tend to need a either a highly standardized environment (execute system("/bin/sh -u root")) or a very specifically crafted attack for a particular device ("Increase centrifuge speed to 'self-destruct' by re-writing PWM register")
"Information leak" is likely to be the usual set of "we didn't clear the packet in between the end of the data we're sending and the end of a minimum-sized packet, so there might be "other" data there."  (clearing memory is a particularly annoying performance sink in limited systems :-( )  Yawn.
« Reply #6 on: October 25, 2018, 11:00:48 am »
Until some does a 360 at BlackHat and proves otherwise. ;D
