Author Topic: How I got the template for Gigadevice GD32E103xx to work in Keil MDK-Lite  (Read 1186 times)
Offline crosswickTopic starter
Hi all,
I thought this was worth sharing. With Keil uVision v5.34 installed, and the 1.20 Addon pack installed within that, I could not get the template (from the 1.20 Firmware Library, all from gigadevice.com) working - it kept giving an error message, and I could not change the Device setting.
Turns out the way to remedy it is to select: Project - Manage - Migrate to Version 5 Format
Then the Device (in Options for Target) is selectable and the right Programming Algorithm for downloading to the MCU is available.
Hope this helps anyone.
« Last Edit: April 26, 2021, 11:51:53 am by crosswick »
Offline techman-001
  • Electronics technician for the last 50 years
    • Mecrisp Stellaris Unofficial UserDoc
Hi all,
Very interesting.
The M4 Gigadevice GD32E103xx LQFP48 package pin-outs are identical to the STM32F103 M3 LQFP48 package as used in the Blue Pill.
https://ipfs-pin.com/ipfs/QmXch2TPefJHeacsKRhfq2gmFsyMAsAXEZ5XASHPi19xtV/GD32E103xx_Datasheet_Rev1.8.pdf
https://ipfs-pin.com/ipfs/QmUFdBU9Lvq3S6hesWy8LrzCm67zHLETyptZ9nGsobrFfP/GD32E10x_User_Manual_Rev1.5.pdf
In the meantime I'm reading in the firmware documentation that the examples are intended to be used in uVision 4, so that's why.
« Last Edit: April 27, 2021, 08:20:42 pm by crosswick »
