I've opened a digital pressure meter in the hopes of adding a serial interface for PC logging. When opening the device I noticed that the device (AT89S52
http://ww1.microchip.com/downloads/en/devicedoc/doc1919.pdf) already has five headers broken out. These are connected to 9V (battery voltage), GND, 10 (RXD), 11 (TXD) and 13 (interrupt). Seems like a serial interface already exists! However, it just remains at idle - I suspect it is waiting for something on the interrupt, but I would like to examine the code if possible.
However, I have no experience with this device, nor with extracting the code from a device. I suspect that it was programmed out of circuit as there are no other connections for programming. in this case, what hardware do I need? What software? I've tried researching, but haven't found any clear information regarding this. I'm a little hesitant to just dive in myself, as I'd prefer to avoid doing something stupid.
If some pics would help, I'd be happy to provide. Thanks in advance.
