That's a very interesting looking board. Thanks for the high-res pic
RAMThree types:
- 1 DIP for 8-bit (occupied)
- 4 DIPS for 32 bits
- more traditional SODIMM (occupied)
I'd guess the 32bit memory bus is split across four 8-bit DIP rams so that it can access them all in parallel, rather than sequentially. Presumably this is an alternative to using the SODIMM.
The 8-bit slot is however more interesting -- did someone mention these processors booting up in an 8-bit mode? Maybe the entire addressing system changed electronically as well as logically, so this processor required an 8-bit RAM chip for boot.
I/OUnless you use some PCI I/O cards you are limited to just RS-232.
By golly that MAX23 at the top-right has a lot of big caps attached, they were not taking any chances about it not being able to charge pump.
EDIT: It comes with an OS built into its EEPROM too. Lots of curly details.
https://www.idt.com/document/mae/79s334a-evaluation-board-manual
