There are a lot of great things a great IDE could do to help.
To make mike and a lot of other people happy it should always be easy to turn on and off an option.
how many times have you looked at someone else's code looking for a side effect in a function? If the IDE had access to the internal compiler data structures this would be easy. no change in what you type would be needed.
For some types of extra help to keep things simple in the long run, some extra typing is the easy thing to allow it to happen. Back in the 80's one language I used did a lot of source error checks, Think double strict what pascal error checking does. Not only did the bit size of a var assignment have to match, but unsigned vis signed mattered as well as the type name but all you had to do was type the following "new_type_name(old_type_var)" this told the compiler that this is OK here and still allow this error checking everywhere else.
This language really under stood what a bit is so that you could easily define in an easy to read and understand structure any thing you might find in the doc's for an F3/F4 arm processor you could easily define. Want a 4 bit var, no problem, and you could use this 4 bit var in the following. If you wanted to create a disassembler you could quickly and easily create a structure for the bits in an instruction set such that you could use a case statement in the main function of the disassembler and get compile errors if you tried to access the second register bits in an instruction that only used one register.
how about helping with the links between ISR code and Main or thread code.
A lot things could be improved and some places it has even been done in special cases but there has to be some changes made to allow it to happen more main stream.
We humans get locked up with 0 or 1 when we should be using Unknown, 0 or more.
Just my thoughts,
C
