PCM, BAM/BCM and PWM are rather different. All can be used to control the average power for a load, or low pass filtered to get an analog voltage, but if you need to control other things than a simple resistive or lighting load, they are no longer directly equivalent.
Choosing to use hardware PWM depends on what library functions are available for the PWM modules (and remember that MCU vendor supplied libraries usually *SUCK*). Without good library support you will have to learn how to set up the PWM modules and the timer(s) that drives them by direct register access, which will mean a lot of time spent studying the datasheet. Without an oscilloscope, or logic analyser it will also be quite difficult to debug.
OTOH, if you use one of the multi-channel software modulation methods, if you have a JTAG or similar in-circuit debugger for your chosen MCU you can step through one line of code at a time, checking the outputs with a logic probe, multimeter or LED. That's a lot easier for anyone with previous C programming experience to get going than having to fully understand the hardware, as outputting a word to a port is remarkably similar for most of the MCU families on the market. Even if you use a timer driven interrupt to maintain the modulation output in the background, that's only one, not excessively complex, hardware peripheral to learn.
Here's that BAM/BCM link again:
http://www.batsocks.co.uk/readme/p_art_bcm.htmIts got C source for an ATmega8 MCU, which, with a bit of work could be ported to an ATmega328P.
Also, if you don't either stick to Atmel's range (that you can program with an Arduino with a programmer sketch loaded), or to chips with a built-in bootloader, you will need a programmer or debugger for whatever MCU you select.
