I've had an interesting couple of days trying to see how I might port a PIC18 design from a couple of years ago onto a faster processor.
The PIC in question was a particularly good fit for the design at the time, not because of the core (which was too slow, and the fragmented memory map was a PITA) but with the other peripherals integrated onto the die. Aside from the voltage regulator to power it, the PIC was about the only active component on the board.
The peripheral set in question? Two analogue comparators, three PWM outputs, an RTC, and some true, byte addressable EEPROM. Plus the usual Flash, RAM, timers and so on which just about every microcontroller has.
I'd hoped that with there being so many ARM Cortex M0 and M0+ micros out there, finding one to replace my PIC would have been easy, but no. EEPROM in particular seems quite rare, which is a great shame because the design really does need to store and update a few bytes at a time at fairly regular intervals. I'm fairly sure it's down to process limitations at the wafer fab... whatever process can make the core for pennies isn't so well suited to fabricating EEPROM cells.
Maybe this particular project is just a bit of an oddball in terms of its requirements?
The other thing which came out of my research is the difference in code space required. The original project fits (just!) into a 32k PIC18. Rewrite it for an STM32 part using the ST peripheral libraries - which, with hindsight, was probably more trouble than it's worth - and it won't fit into a 64k device without optimisation. Flash capacity would appear not to be directly comparable between the families, despite the fact that the Cortex M0 uses 16 bit (Thumb) instructions to improve code density. It's not a particularly I/O intensive project, most of the code is application level and stored bitmap graphics, so the impact of the more complex peripherals is minimal.
If anyone has any suggestions for a device with the necessary peripherals but about, say, twice the performance of a PIC18 @ 64 MHz, I'd be genuinely appreciative. If it's a similar price, so much the better!
