Author Topic: why Compiling for Cortex M7 is painfully slow  (Read 671 times)
Offline ali_asadzadeh
« on: August 01, 2020, 12:10:01 pm »
This is the first time moving to M7, it's a STM32H750 and I'm using keil,
The compilation is painfully very slow, is something wrong? any Ideas?
I'm a Digital Expert from 8-bits to 64-bits
Offline brucehoult
  • Formerly SiFive, Samsung R&D
Re: why Compiling for Cortex M7 is painfully slow
« Reply #1 on: August 01, 2020, 12:25:06 pm »
I've got a board (Teensy 4.0) with a Cortex M7. gcc seems to compile good optimized code for it just as quickly as for anything else. (I've never seen keil).
The CPU really flies too.
Offline unitedatoms
« Reply #2 on: August 01, 2020, 12:30:34 pm »
On Cortex M0 Keil Compiler 5 is slower than Compiler 6 for my projects. I recently migrated to Compiler 6 to have more warnings to learn C. It is possibly LLVM making compilation faster.
Do you have latest Compiler in KEIL project settings ?
Interested in all design related projects no matter how simple, or complicated, slow going or fast, failures or successes
Offline Siwastaja
« Reply #3 on: August 01, 2020, 01:30:31 pm »
At least for me, GCC has no problem whatsoever. For example, a 25000 LoC project of about 40 files for Cortex-M7 with arm-none-eabi toolchain seems to take 3 seconds on single thread, single sequential make process, on a el-cheapo Asus laptop with Intel Core i3-8130U CPU @ 2.20GHz. Partially -O3, partially -Os.
Maybe the problem is with Keil.
Offline hansd
« Reply #4 on: August 01, 2020, 01:38:53 pm »
Check also the exploit protections in your virus scan. You might have to exclude Keil and your project directory. I saw this with STM32CubeMX. After exclusion it reduced the build time from 90 seconds to a few seconds.
Offline newbrain
« Reply #5 on: August 01, 2020, 03:41:50 pm »
Another sample point, still arm-none-eabi-gcc, 200 kLOC over about 330 .c and .h files:
 less than 7 s after a make clean, "make -j 16 all" on an AMD 2700X.
Offline mikerj
« Reply #6 on: August 01, 2020, 07:12:08 pm »
Have you configured Keil to generate all the various debug type files, e.g. pre-processor, list etc?  That can really slow things down IME, especially when combined with a sluggish realtime virus scanner (corporate, so have to jump through hoops to get folders excluded).
Offline Nominal Animal
« Reply #7 on: August 02, 2020, 12:36:52 am »
Cortex-M7 is not that different from Cortex-M4 from the compiler point of view – they're both ARMv7E-M –, so it's not Cortex M7 that is the issue here, it's the compiler.
(According to ARM Cortex-M7 docs, binaries that do not use floating-point compiled for Cortex-M3 or Cortex-M4 can run as-is on Cortex-M7.)
Offline brucehoult
« Reply #8 on: August 02, 2020, 12:47:33 am »
They won't be optimally scheduled for the dual-issue M7.
That is something a compiler *could* spend some time on optimizing. It would have to be using really bad algorithms to be noticeable though.
The following users thanked this post: hans, newbrain
Offline westfw
« Reply #9 on: August 02, 2020, 02:15:13 am »
Is it compiler, or "upload" that is slow?
I've noticed that there's a wide variation in the efficiency of the upload algorithms for CMSIS-DAP devices."Early", they seem to get flash controller registers defined, and programming proceeds by issuing individual commands to the registers, updating RAM one word at a time, and so on.  "Later" someone implements higher-level code where a "helper" routine is loaded into RAM, and it does something more like block-based programming (faster!)  Or something like that.
Offline lucazader
« Reply #10 on: August 02, 2020, 04:33:57 am »
i had noticed that the keil compiler was very slow with m7 core's in the past.
It was one of the may reasons that i move over to using gcc.
« Reply #11 on: August 02, 2020, 10:16:31 am »
Thanks for your feedback, this is the settings for my simple Test project, everything is generated by Cube, and I just have added a few files to the project, I'm very early in development.
Also I have disabled the windows defender for now, Nothing changed :'(
The project files are very huge, around 500MB! I will just upload the Cube file, If you are interested just generate the project with Cube and make the project, it will take 3 minutes to build and complie the project :'( :-- :-- :-- :--
I have a core I7 cpu and 8GB ram and 1TB SSD ???
The Graphic cube project is attached and you can play with
Offline hans
« Reply #12 on: August 02, 2020, 11:40:14 am »
I loaded your .ioc file. Generated code for toolchain SW4STM32. Loaded folder (.ioc + source) in CLion with embedded project type.
Build using ARM GCC 9.2 on Manjaro Linux on 8 threads (Intel i7 6700HQ Thinkpad laptop): 1.695sec, no optimizer -O0
[100%] Linking C executable Graphic.elf
Memory region         Used Size  Region Size  %age Used
         DTCMRAM:        4920 B       128 KB      3.75%
          RAM_D1:          0 GB       512 KB      0.00%
          RAM_D2:          0 GB       288 KB      0.00%
          RAM_D3:          0 GB        64 KB      0.00%
         ITCMRAM:          0 GB        64 KB      0.00%
           FLASH:       51428 B       128 KB     39.24%
With optimizer -Os: 2.495sec
           FLASH:       28512 B       128 KB     21.75%
With SW4STM32 target the project folder is only 11MB. I think the other type is much larger, as it includes various math libraries..
Anyway, do you have a parallel compilation option for Keil? IME Keil isn't the fastest toolchain, but 3min is very slow and IMO unusable (even with incremental compilation).
« Last Edit: August 02, 2020, 11:43:43 am by hans »
« Reply #13 on: August 02, 2020, 01:23:53 pm »
Thanks, I have switched the compiler to version 6, now it compiles around 5 seconds.
