Just last night I bought the software and ISP programmer for Motorola / Freescale / NXP HCS08 micros and was left with 58 cents change from AUD$1K... It’s probably a rare hobbyist that is going to buy one of those. The point is, if the cost to get started with them was a whole lot lower, like with PIC for example, then a whole lot more people would start with them and probably continue to specify them if they made a career out of it. You would think the semi manufacturer would understand such a simple concept!
Wow, that's a lot of money to feed a Motorola ISA obsession
Whilst my first ISA love affair was with the MC6800 it eventually gave way to the STM32F0 ARM Cortex M0 for which almost all the tools are free, and STM even give away the complete unrestricted, un-crippled Atollic Studio,
https://atollic.com/truestudio/ which is very impressive if you're into C or assembly. Just make sure you have a 4 core I7 with 32GB ram to run it all!
Even a 'low end' 32 bit STM32F051 with 64KB Flash, 8KB Ram, 48MHz internal clock and 37 onboard peripherals can be had for $0.56 each, which makes them very hard to resist.
While some of the worlds largest MCU manufacturers (such as STM) do give away the necessary tools, most don't and still cling to the old ways of charging a arm and a leg for tools to use their hardware, which has always struck me as crazy since I started doing embedded around 1976.
