Author Topic: Why is my FPGA blinky not blinking (iCE40HX8K)  (Read 5716 times)
Offline MattHollandsTopic starter
    • Matt's Projects
« on: August 22, 2018, 07:42:27 pm »
I have just got some FPGA boards back from the fab and am just trying to bring them up by controlling the LED. But for some reason it's not doing what I want.
I am using an iCE40HX8K in the 121 bga package and lattice Diamond programmer and iCECube2. Schematic attached. It programs fine via a FT2232H mini module and the done pin asserts after I program it. I can read back the program and verify that it is programmed correctly.
(Of the components shown in the schematic, everything is stuffed except C502, C505, C504, C506 which should be fine as I'm not using a PLL yet).
My Verilog code:
module main(output LED, output DEBUG7);
assign LED = 1;
assign DEBUG7 = 1;
endmodule
My constraints file:
set_io DEBUG7 E2 -pullup no
set_io LED J8 -pullup no
The LED D102 should turn on after programming but it doesn't. I've measured the voltage across D102 and it's around 900mV, regardless of whether I set LED = 0 or LED = 1.
D102 does turn on if I turn on the internal pull-up however I then cannot turn it off! D102 is also on pre-configuration because the pull-ups are engaged, but turns off once I program the FPGA.
(Everything I've said here is also true for pin DEBUG7). 3V3 and 1V2 rails are fine.
I'm hoping I'm doing something stupid...
Here is the log from iCECube2:
"C:\lscc\iCEcube2.2017.08\sbt_backend\bin\win32\opt\synpwrap\synpwrap.exe" -prj "TestHP2VGA_syn.prj" -log "TestHP2VGA_Implmnt/TestHP2VGA.srr"
Copyright (C) 1992-2014 Lattice Semiconductor Corporation. All rights reserved.
==contents of TestHP2VGA_Implmnt/TestHP2VGA.srr
#Build: Synplify Pro L-2016.09L+ice40, Build 077R, Dec  2 2016
#install: C:\lscc\iCEcube2.2017.08\synpbase
#OS: Windows 8 6.2
#Hostname: DESKTOP-6I79T4A
# Wed Aug 22 20:30:08 2018
#Implementation: TestHP2VGA_Implmnt
Synopsys HDL Compiler, version comp2016q3p1, Build 141R, built Dec  5 2016
@N|Running in 64-bit mode
Copyright (C) 1994-2016 Synopsys, Inc. All rights reserved. This Synopsys software and all associated documentation are proprietary to Synopsys, Inc. and may only be used pursuant to the terms and conditions of a written license agreement with Synopsys, Inc. All other use, reproduction, modification, or distribution of the Synopsys software or the associated documentation is strictly prohibited.
Synopsys Verilog Compiler, version comp2016q3p1, Build 141R, built Dec  5 2016
@I::"C:\lscc\iCEcube2.2017.08\synpbase\lib\generic\sb_ice40.v" (library work)
@I::"C:\lscc\iCEcube2.2017.08\synpbase\lib\vlog\hypermods.v" (library __hyper__lib__)
@I::"C:\lscc\iCEcube2.2017.08\synpbase\lib\vlog\umr_capim.v" (library snps_haps)
@I::"C:\lscc\iCEcube2.2017.08\synpbase\lib\vlog\scemi_objects.v" (library snps_haps)
@I::"C:\lscc\iCEcube2.2017.08\synpbase\lib\vlog\scemi_pipes.svh" (library snps_haps)
@I::"C:\Users\Matt\Downloads\main.v" (library work)
Verilog syntax check successful!
File C:\Users\Matt\Downloads\main.v changed - recompiling
Selecting top level module main
@N: CG364 :"C:\Users\Matt\Downloads\main.v":1:7:1:10|Synthesizing module main in library work.
At c_ver Exit (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 69MB peak: 70MB)
Process took 0h:00m:01s realtime, 0h:00m:01s cputime
Process completed successfully.
# Wed Aug 22 20:30:09 2018
Synopsys Netlist Linker, version comp2016q3p1, Build 141R, built Dec  5 2016
@N: NF107 :"C:\Users\Matt\Downloads\main.v":1:7:1:10|Selected library: work cell: main view verilog as top level
At syn_nfilter Exit (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 67MB peak: 68MB)
@END
At c_hdl Exit (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 3MB peak: 4MB)
File C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\synwork\TestHP2VGA_comp.srs changed - recompiling
# Wed Aug 22 20:30:10 2018
Pre-mapping Report
# Wed Aug 22 20:30:11 2018
Synopsys Lattice Technology Pre-mapping, Version maplat, Build 1612R, Built Dec  5 2016 10:31:39
Product Version L-2016.09L+ice40
Mapper Startup Complete (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 99MB peak: 99MB)
@A: MF827 |No constraint file specified.
@L: C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\TestHP2VGA_scck.rpt
Printing clock  summary report in "C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\TestHP2VGA_scck.rpt" file
@N: MF248 |Running in 64-bit mode.
@N: MF666 |Clock conversion enabled. (Command "set_option -fix_gated_and_generated_clocks 1" in the project file.)
Design Input Complete (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 99MB peak: 101MB)
Mapper Initialization Complete (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 99MB peak: 101MB)
Start loading timing files (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 100MB peak: 101MB)
Finished loading timing files (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 100MB peak: 102MB)
ICG Latch Removal Summary:
Number of ICG latches removed: 0
Number of ICG latches not removed: 0
syn_allowed_resources : blockrams=32  set on top level netlist main
Finished netlist restructuring (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 131MB peak: 133MB)
Clock Summary
Start     Requested     Requested     Clock     Clock     Clock
Clock     Frequency     Period        Type      Group     Load
Finished Pre Mapping Phase.
@N: BN225 |Writing default property annotation file C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\TestHP2VGA.sap.
Starting constraint checker (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 131MB peak: 133MB)
None
None
Finished constraint checker (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 131MB peak: 133MB)
Pre-mapping successful!
At Mapper Exit (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 46MB peak: 133MB)
# Wed Aug 22 20:30:12 2018
Map & Optimize Report
Synopsys Lattice Technology Mapper, Version maplat, Build 1612R, Built Dec  5 2016 10:31:39
Design Input Complete (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 98MB peak: 100MB)
Mapper Initialization Complete (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 98MB peak: 100MB)
Start loading timing files (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 100MB peak: 100MB)
Starting Optimization and Mapping (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 131MB peak: 133MB)
Available hyper_sources - for debug and ip models
None Found
@N: MT206 |Auto Constrain mode is enabled
Finished RTL optimizations (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 130MB peak: 133MB)
Starting factoring (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 130MB peak: 133MB)
Finished factoring (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 130MB peak: 133MB)
Finished gated-clock and generated-clock conversion (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 130MB peak: 133MB)
Finished generic timing optimizations - Pass 1 (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 130MB peak: 133MB)
Starting Early Timing Optimization (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 130MB peak: 133MB)
Finished Early Timing Optimization (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 130MB peak: 133MB)
Finished generic timing optimizations - Pass 2 (Real Time elapsed 0h:00m:00s; CPU Time elapsed 0h:00m:00s; Memory used current: 130MB peak: 133MB)
Finished preparing to map (Real Time elapsed 0h:00m:01s; CPU Time elapsed 0h:00m:00s; Memory used current: 130MB peak: 133MB)
Finished technology mapping (Real Time elapsed 0h:00m:01s; CPU Time elapsed 0h:00m:00s; Memory used current: 130MB peak: 133MB)
Pass CPU time Worst Slack Luts / Registers
Finished technology timing optimizations and critical path resynthesis (Real Time elapsed 0h:00m:01s; CPU Time elapsed 0h:00m:01s; Memory used current: 130MB peak: 133MB)
Finished restoring hierarchy (Real Time elapsed 0h:00m:01s; CPU Time elapsed 0h:00m:01s; Memory used current: 130MB peak: 133MB)
@S |Clock Optimization Summary
#### START OF CLOCK OPTIMIZATION REPORT #####[
0 non-gated/non-generated clock tree(s) driving 0 clock pin(s) of sequential element(s)
0 gated/generated clock tree(s) driving 0 clock pin(s) of sequential element(s)
0 instances converted, 0 sequential instances remain driven by gated/generated clocks
##### END OF CLOCK OPTIMIZATION REPORT ######]
Start Writing Netlists (Real Time elapsed 0h:00m:01s; CPU Time elapsed 0h:00m:01s; Memory used current: 105MB peak: 133MB)
Writing Analyst data base C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\synwork\TestHP2VGA_m.srm
Finished Writing Netlist Databases (Real Time elapsed 0h:00m:01s; CPU Time elapsed 0h:00m:01s; Memory used current: 129MB peak: 133MB)
Writing EDIF Netlist and constraint files
@N: BW103 |The default time unit for the Synopsys Constraint File (SDC or FDC) is 1ns.
@N: BW107 |Synopsys Constraint File capacitance units using default value of 1pF
@N: FX1056 |Writing EDF file: C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\TestHP2VGA.edf
L-2016.09L+ice40
Finished Writing EDIF Netlist and constraint files (Real Time elapsed 0h:00m:02s; CPU Time elapsed 0h:00m:01s; Memory used current: 130MB peak: 133MB)
Start final timing analysis (Real Time elapsed 0h:00m:02s; CPU Time elapsed 0h:00m:02s; Memory used current: 131MB peak: 133MB)
##### START OF TIMING REPORT #####[
# Timing Report written on Wed Aug 22 20:30:14 2018
Top view:               main
Requested Frequency:    1.0 MHz
Wire load mode:         top
Paths requested:        5
Constraint File(s):
@N: MT320 |This timing report is an estimate of place and route data. For final timing results, use the FPGA vendor place and route report.
@N: MT322 |Clock constraints include only register-to-register paths associated with each individual clock.
Performance Summary
Worst slack in design: NA
Clock Relationships
Clocks            |    rise  to  rise   |    fall  to  fall   |    rise  to  fall   |    fall  to  rise
Starting  Ending  |  constraint  slack  |  constraint  slack  |  constraint  slack  |  constraint  slack
 Note: 'No paths' indicates there are no paths in the design for that pair of clock edges.
       'Diff grp' indicates that paths exist but the starting clock and ending clock are in different clock groups.
Interface Information
No IO constraint found
##### END OF TIMING REPORT #####]
Timing exceptions that could not be applied
None
Finished final timing analysis (Real Time elapsed 0h:00m:02s; CPU Time elapsed 0h:00m:02s; Memory used current: 131MB peak: 133MB)
Finished timing report (Real Time elapsed 0h:00m:02s; CPU Time elapsed 0h:00m:02s; Memory used current: 131MB peak: 133MB)
Resource Usage Report for main
Mapping to part: ice40hx8kct256
Cell usage:
SB_LUT4         0 uses
I/O ports: 2
I/O primitives: 2
SB_IO          2 uses
I/O Register bits:                  0
Register bits not including I/Os:   0 (0%)
Total load per clock:
@S |Mapping Summary:
Total  LUTs: 0 (0%)
Mapper successful!
At Mapper Exit (Real Time elapsed 0h:00m:02s; CPU Time elapsed 0h:00m:02s; Memory used current: 25MB peak: 133MB)
Process took 0h:00m:02s realtime, 0h:00m:02s cputime
# Wed Aug 22 20:30:15 2018
Synthesis exit by 0.
Current Implementation TestHP2VGA_Implmnt its sbt path: C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt
Synthesis succeeded.
Synthesis runtime 9 seconds
"C:/lscc/iCEcube2.2017.08/sbt_backend/bin/win32/opt\edifparser.exe" "C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev" "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt/TestHP2VGA.edf " "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\netlist" "-pBG121" "-yC:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt/sbt/constraint/main_pcf_sbt.pcf " -c --devicename iCE40HX8K
Lattice Semiconductor Corporation  Edif Parser
Release:        2017.08.27940
Build Date:     Sep 11 2017 16:51:25
Parsing edif file: C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt/TestHP2VGA.edf...
Parsing constraint file: C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt/sbt/constraint/main_pcf_sbt.pcf ...
start to read sdc/scf file C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt/TestHP2VGA.scf
sdc_reader OK C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt/TestHP2VGA.scf
Stored edif netlist at C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\netlist\oadb-main...
write Timing Constraint to C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt/Temp/sbt_temp.sdc
EDIF Parser succeeded
Top module is: main
EDF Parser run-time: 1 (sec)
"C:/lscc/iCEcube2.2017.08/sbt_backend/bin/win32/opt\sbtplacer.exe" --des-lib "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\netlist\oadb-main" --outdir "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\placer" --device-file "C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev" --package BG121 --deviceMarketName iCE40HX8K --sdc-file "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\Temp/sbt_temp.sdc" --lib-file "C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ice40HX8K.lib" --effort_level std --out-sdc-file "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\placer\main_pl.sdc"
Executing : C:\lscc\iCEcube2.2017.08\sbt_backend\bin\win32\opt\sbtplacer.exe --des-lib C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\netlist\oadb-main --outdir C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\placer --device-file C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev --package BG121 --deviceMarketName iCE40HX8K --sdc-file C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\Temp/sbt_temp.sdc --lib-file C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ice40HX8K.lib --effort_level std --out-sdc-file C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\placer\main_pl.sdc
Lattice Semiconductor Corporation  Placer
Build Date:     Sep 11 2017 17:12:23
I2004: Option and Settings Summary
Device file          - C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev
Package              - BG121
Design database      - C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\netlist\oadb-main
SDC file             - C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\Temp/sbt_temp.sdc
Output directory     - C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\placer
Timing library       - C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ice40HX8K.lib
Effort level         - std
I2050: Starting reading inputs for placer
I2100: Reading design library: C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\netlist\oadb-main/BFPGA_DESIGN_ep
I2065: Reading device file : C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev
I2051: Reading of inputs for placer completed successfully
I2053: Starting placement of the design
Input Design Statistics
    Number of LUTs      : 0
    Number of DFFs      : 0
    Number of DFFs packed to IO : 0
    Number of Carrys    : 0
    Number of RAMs      : 0
    Number of ROMs      : 0
    Number of IOs        : 2
    Number of GBIOs      : 0
    Number of GBs        : 0
    Number of WarmBoot  : 0
    Number of PLLs      : 0
Phase 1
I2077: Start design legalization
Design Legalization Statistics
    Number of feedthru LUTs inserted to legalize input of DFFs      : 0
    Number of feedthru LUTs inserted for LUTs driving multiple DFFs : 0
    Number of LUTs replicated for LUTs driving multiple DFFs        : 0
    Number of feedthru LUTs inserted to legalize output of CARRYs  : 0
    Number of feedthru LUTs inserted to legalize global signals    : 0
    Number of feedthru CARRYs inserted to legalize input of CARRYs : 0
    Number of inserted LUTs to Legalize IOs with PIN_TYPE= 01xxxx  : 0
    Number of inserted LUTs to Legalize IOs with PIN_TYPE= 10xxxx  : 0
    Number of inserted LUTs to Legalize IOs with PIN_TYPE= 11xxxx  : 0
    Total LUTs inserted                                            : 0
    Total CARRYs inserted                                          : 0
I2078: Design legalization is completed successfully
I2088: Phase 1, elapsed time : 0.0 (sec)
Phase 2
I2088: Phase 2, elapsed time : 0.1 (sec)
Phase 3
Design Statistics after Packing
    Number of LUTs      : 1
    Number of DFFs      : 0
Device Utilization Summary after Packing
    Sequential LogicCells
        LUT and DFF      : 0
        LUT, DFF and CARRY : 0
    Combinational LogicCells
        Only LUT          : 1
        CARRY Only        : 0
        LUT with CARRY    : 0
    LogicCells                  : 1/7680
    PLBs                        : 1/960
    BRAMs                       : 0/32
    IOs and GBIOs               : 2/93
    PLLs                        : 0/2
I2088: Phase 3, elapsed time : 0.4 (sec)
Phase 4
W2659: No Constrained paths were found. The placer will run in non-timing driven mode.
I2088: Phase 4, elapsed time : 0.4 (sec)
Phase 5
I2088: Phase 5, elapsed time : 0.0 (sec)
Phase 6
I2088: Phase 6, elapsed time : 0.0 (sec)
Final Design Statistics
    Number of LUTs      : 1
    Number of DFFs      : 0
    Number of RAMs      : 0
    Number of ROMs      : 0
    Number of IOs        : 2
    Number of GBIOs      : 0
    Number of GBs        : 0
    Number of PLLs      : 0
    LogicCells                  : 1/7680
    PLBs                        : 1/960
    BRAMs                       : 0/32
    PLLs                        : 0/2
I2054: Placement of design completed successfully
I2076: Placer run-time: 2.2 sec.
"C:/lscc/iCEcube2.2017.08/sbt_backend/bin/win32/opt\packer.exe" "C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev" "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\netlist\oadb-main" --package BG121 --outdir "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\packer" --DRC_only  --translator "C:\lscc\iCEcube2.2017.08\sbt_backend\bin\sdc_translator.tcl" --src_sdc_file "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\placer\main_pl.sdc" --dst_sdc_file "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\packer\main_pk.sdc" --devicename iCE40HX8K
Lattice Semiconductor Corporation  Packer
Build Date:     Sep 11 2017 16:52:47
Begin Packing...
initializing finish
Total HPWL cost is 42
used logic cells: 1
Design Rule Checking Succeeded
DRC Checker run-time: 1 (sec)
"C:/lscc/iCEcube2.2017.08/sbt_backend/bin/win32/opt\packer.exe" "C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev" "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\netlist\oadb-main" --package BG121 --outdir "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\packer" --translator "C:\lscc\iCEcube2.2017.08\sbt_backend\bin\sdc_translator.tcl" --src_sdc_file "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\placer\main_pl.sdc" --dst_sdc_file "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\packer\main_pk.sdc" --devicename iCE40HX8K
Begin Packing...
initializing finish
used logic cells: 1
Translating sdc file C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\placer\main_pl.sdc...
Translated sdc file is C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\packer\main_pk.sdc
Packer succeeded
Packer run-time: 1 (sec)
"C:\lscc\iCEcube2.2017.08\sbt_backend\bin\win32\opt\sbrouter.exe" "C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev" "C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\sbt\netlist\oadb-main" "C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ice40HX8K.lib" "C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\sbt\outputs\packer\main_pk.sdc" --outdir "C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\sbt\outputs\router" --sdf_file "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\simulation_netlist\main_sbt.sdf" --pin_permutation
SJRouter....
Executing : C:\lscc\iCEcube2.2017.08\sbt_backend\bin\win32\opt\sbrouter.exe C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\sbt\netlist\oadb-main C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ice40HX8K.lib C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\sbt\outputs\packer\main_pk.sdc --outdir C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\sbt\outputs\router --sdf_file C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\simulation_netlist\main_sbt.sdf --pin_permutation
Lattice Semiconductor Corporation  Router
Build Date:     Sep 11 2017 17:02:50
I1203: Reading Design main
Read design time: 0
I1202: Reading Architecture of device iCE40HX8K
Read device time: 16
I1209: Started routing
I1223: Total Nets : 1
I1212: Iteration  1 :     0 unrouted : 0 seconds
I1215: Routing is successful
Routing time: 1
I1206: Completed routing
I1204: Writing Design main
Lib Closed
I1210: Writing routes
I1218: Exiting the router
I1224: Router run-time : 17 seconds
"C:/lscc/iCEcube2.2017.08/sbt_backend/bin/win32/opt\netlister.exe" --verilog "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\simulation_netlist\main_sbt.v" --vhdl "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt/sbt/outputs/simulation_netlist\main_sbt.vhd" --lib "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\netlist\oadb-main" --view rt --device "C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev" --splitio  --in-sdc-file "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\packer\main_pk.sdc" --out-sdc-file "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\netlister\main_sbt.sdc"
Lattice Semiconductor Corporation  Verilog & VHDL Netlister
Build Date:     Sep 11 2017 17:30:26
Generating Verilog & VHDL netlist files ...
Writing C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\simulation_netlist\main_sbt.v
Writing C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt/sbt/outputs/simulation_netlist\main_sbt.vhd
Netlister succeeded.
Netlister run-time: 1 (sec)
"C:/lscc/iCEcube2.2017.08/sbt_backend/bin/win32/opt\sbtimer.exe" --des-lib "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\netlist\oadb-main" --lib-file "C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ice40HX8K.lib" --sdc-file "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\netlister\main_sbt.sdc" --sdf-file "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\simulation_netlist\main_sbt.sdf" --report-file "C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\sbt\outputs\timer\main_timing.rpt" --device-file "C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev" --timing-summary
Executing : C:\lscc\iCEcube2.2017.08\sbt_backend\bin\win32\opt\sbtimer.exe --des-lib C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\netlist\oadb-main --lib-file C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ice40HX8K.lib --sdc-file C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\netlister\main_sbt.sdc --sdf-file C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\simulation_netlist\main_sbt.sdf --report-file C:\Users\Matt\Downloads\TestHP2VGA\TestHP2VGA_Implmnt\sbt\outputs\timer\main_timing.rpt --device-file C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev --timing-summary
Lattice Semiconductor Corporation  Timer
Build Date:     Sep 11 2017 17:01:05
Timer run-time: 1 seconds
timer succeeded.
"C:/lscc/iCEcube2.2017.08/sbt_backend/bin/win32/opt\bitmap.exe" "C:\lscc\iCEcube2.2017.08\sbt_backend\devices\ICE40P08.dev" --design "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\netlist\oadb-main" --device_name iCE40HX8K --package BG121 --outdir "C:/Users/Matt/Downloads/TestHP2VGA/TestHP2VGA_Implmnt\sbt\outputs\bitmap" --low_power on --init_ram on --init_ram_bank 1111 --frequency low --warm_boot on
Lattice Semiconductor Corporation  Bit Stream Generator
Build Date:     Sep 11 2017 17:29:39
Bit Stream File Size: 1080760 (1M 31K 440 Bits)
Bit Stream Generator succeeded
Bitmap run-time: 1 (sec)
Please spot my mistake!
« Last Edit: August 22, 2018, 07:45:56 pm by MattHollands »
Read about my stuff at: projects.matthollands.com
Offline asmi
Re: Why is my FPGA blinky not blinking (iCE40HX8K)
« Reply #1 on: August 22, 2018, 09:10:45 pm »
I don't have IceCube handy, but I would check if you set up correct Vccio voltages for all banks. Wrong settings can lead to FPGA IO buffers doing funny things...
    • Matt's Projects
« Reply #2 on: August 22, 2018, 09:30:21 pm »
Verified :( not solved
Offline jmelson
« Reply #3 on: August 22, 2018, 10:08:07 pm »
I don't see a clock anywhere on your schematics.
Jon
    • Matt's Projects
« Reply #4 on: August 22, 2018, 10:10:13 pm »
Jon
Why do I need a clock? There will be a clock later on, but do I need one if I'm just using combinational logic?
    • Matt's Projects
« Reply #5 on: August 23, 2018, 12:14:50 am »
Ok some new evidence has come to light but I don't know how to explain it.
If I tap the board repeatedly with a metal implement (e.g. my tweezers, or a single (floating) multimeter lead), eventually the board comes to life and the led turns on and DEBUG7 goes high etc... It seems like the small amount of voltage on my body from being in an electrically noisey environment can suddenly trigger the FPGA to start responding if I touch it at the right time and right place. You can also see that before the FPGA starts, the LED is lighting up from this voltage.
This is very repeatable and seems to happen only with metal objects (makes sense) but I can be touching lots of different places on the board (e.g. ground, random input pins, the LED).
I really can't explain what is happening! My power supply is floating (I realise it won't be perfectly floating and there will be some capacitance to earth).
Please give me your suggestions?
https://youtu.be/RATjZ0fGiv4
The red LEDs are power and DONE from the fpga. The geen LED is D102 which should turn on as soon as I program the FPGA.
« Last Edit: August 23, 2018, 12:16:36 am by MattHollands »
Offline BrianHG
« Reply #6 on: August 23, 2018, 12:32:44 am »
Floating input, like a dedicated chip wide reset, or, global output enable pin.  Even if these pins are wired, there may be a cold joint under the BGA...
This includes the programming port, including auxiliary JTAG which overrides all the FPGA's functions instantly.
Some of these unused pins might be configurable as outputs or a generic data input, which programming them as so would stop this from happening...
If these pins are dedicated inputs, well, then you need to tie them to a pullup or pull down, otherwise, you see your problem.
Also, don't forget, even if you aren't using them, the PLL VCCs nee to be powered.
All unused IO and inputs must be pulled up or down, for the outputs, you can drive them high or low.
Scope all your power supply VCCs while programming, you might see the funny thing that happens when floating input pins become active after programming.  Hint: Good proper powersupply decoupling caps helps alleviates this...
« Last Edit: August 23, 2018, 12:46:36 am by BrianHG »
    • Matt's Projects
« Reply #7 on: August 23, 2018, 12:58:32 am »
Hi Brian,
The chip's global reset pin must be soldered ok because the programmer uses it during programming... Also if the chip was resetting, the DONE pin would de-assert, which it doesn't.
The FPGA doesn't have JTAG, only SPI interface for programming.
The problem of the LED not turning on happened even when all unused IOs were pulled up (which is the default setting in iCECube2).
The PLLs are powered, R501 and R502 are stuffed, just not the capacitors.
Will scope my VCCs tomorrow.
Can you explain how a cold joint would cause this to occur? Would you suggest a reflow?
    • Matt's Projects
« Reply #8 on: August 23, 2018, 01:08:20 am »
Update: the weird bug with the tweezers works even when there are no floating IOs
Offline BrianHG
« Reply #9 on: August 23, 2018, 02:10:32 am »
Your tweezers are acting as a capacitor on that IO line.  You need to scope the power supply as close to the IC's programming IO supply as possible.
Open contact on slow BGA input pins, like reset, can still work based on just being so close.  If the IO pin for the led is so close to the reset which is truly open, the high speed of that IO pin can capacitively bridge to the adjacent open reset input pin with something like a 1-2pf, causing a fluttering loop reset until adding the capaccitive load of the tweezer on that IO slows down the IO to a point where that 1-2pf series bridge to the reset pin wont spike the reset input.  Once the led is on, removing the tweezer allows the device to continue to function since the IO stays at one level.
No decoupling on the power supply, or, improperly uncleaned flux residue under the BGA can also cause the same problem.  Adding a stronger pullup on the reset input will also help prevent the problem.
« Last Edit: August 23, 2018, 02:12:14 am by BrianHG »
Offline iMo
  • Country: pm
  • It's important to try new things..
« Reply #10 on: August 23, 2018, 07:38:32 pm »
If I were you I would
1. modify the verilog -> add an input pin,
2. connect the input pin with the output to the LED (you may invert if you wish),
3. compile and flash into the fpga.
While changing the input level observe the LED.
2 minutes of work..
    • Matt's Projects
« Reply #11 on: August 23, 2018, 08:08:30 pm »
I have scoped directly across the decoupling caps on the underside of the FPGA. I see a massive Vpp pre-configuration when the programmer is connected... like 500mVpp. But after programming this drops to 60mVpp on 3V3 and 120mVpp on 1V2. Regardless of whether all pins are floating or pulled up it is the same.
I tried putting a 1,5nF and a 100nF cap across the LED to add capacitance and this did not make a difference.
I cleaned the flux off the board with IPA. No difference. Although obviously I cannot clean under the FPGA.
I can measure the reverse voltage protection diode on the reset pin a 550mV which is the same as on any of the input pins. This, to me, suggests that it is connected just fine.
2 minutes of work..
Given what we already know, the LED will stay off until I poke it with my tweezers and the FPGA springs to life at which point the FPGA does exactly what you expect and the LED turns on and off with the input. Nonetheless, I tried it and it does exactly that.
Going to try adding 0.01uF decoupling caps in parallel with my 0.1uF caps. But otherwise I am somewhat at a loss other than trying to reflow the board, but that's annoying because I'll have to remove a bunch of components first.
Offline jmelson
« Reply #12 on: August 23, 2018, 08:35:58 pm »
Jon
How's an LED going to blink without a clock?  Are you going to command it from something external?
Anyway, might check your FPGA synthesis reports to make sure it didn't throw in any FFs that you are not aware of.
Very easy for that to happen, as the tools do NOT LIKE totally unclocked designs.
Jon
    • Matt's Projects
« Reply #13 on: August 23, 2018, 08:37:34 pm »
If you look at my verilog code it's pretty obvious I'm not trying to flash it. The LED just won't turn on. Except when I touch it with tweezers as discussed in the rest of the thrad... |O
    • Matt's Projects
« Reply #14 on: August 23, 2018, 08:38:18 pm »
Adding 0.01uF caps in parallel with the 0.1uF ones did not help.
    • Matt's Projects
« Reply #15 on: August 23, 2018, 08:49:44 pm »
If I ground myself the tweezer trick doesn't work.
Offline iMo
  • Country: pm
« Reply #16 on: August 23, 2018, 08:58:40 pm »
Is the R603 populated?
    • Matt's Projects
« Reply #17 on: August 23, 2018, 09:08:11 pm »
Offline BrianHG
« Reply #18 on: August 23, 2018, 09:17:14 pm »
DO not add a 100nf cap to the LED.  If you want to mimic the tweezers, add a 10pf to 100pf cap across the LED and VCC or GND.  Try probing the LED, the scope probe tip may also have the same effect as the tweezers.  100nf will make thing royally worse...
When probing the power and probing the reset, is your probe GND connected to near the same cap where you are measuring the VCC.  Is your scope set to trigger and capture the slightest voltage spike down at the +/-50mv from target VCC voltage & 10ns/division or less, sampling at full speed?  You should be capturing a spike after the PLD boots up, not that large programmer source signal?  Is the input channel bandwidth at full using 10x probes?
« Last Edit: August 23, 2018, 09:18:47 pm by BrianHG »
Offline iMo
  • Country: pm
« Reply #19 on: August 23, 2018, 09:20:19 pm »
It is my understanding you do not use an external flash for the bitstream.
Am I right?
Offline NorthGuy
« Reply #20 on: August 23, 2018, 09:30:03 pm »
I would suspect the LED is not soldered well. Instead of looking at the LED, probe the voltage on the resistor.
    • Matt's Projects
« Reply #21 on: August 23, 2018, 09:44:04 pm »
Why will 100nF make it worse? It's after a 2k2 resistor anyway.
Probing scheme attached. On the 3v3 rail it is set to about 50mV above and does not trigger at all during programming. 1v2 there is about 100mVpp noise anyway when the programmer is connected. There is an increase in noise measured during programming but no spike stands out. Scope is set to full bandwidth using 10x probes.
I don't understand how your theory explains the fact that I can touch ANY FPGA GPIO (even unused ones) and it will start working. These unused GPIOs are not trying to go high, they should just have an internal pull-up resistor. Why would adding capacitance to these pins suddenly make the FPGA work? Will post a video in a minute.
Am I right?
Yes programming directly over SPI interface using FT2232H
It is soldered fine. Read the rest of the post. A) if the led was not connected then we would still see 3V3 on one of the pins. B) This happens on NC outputs C) it wouldn't start working when I touch other pins.
    • Matt's Projects
« Reply #22 on: August 23, 2018, 09:46:48 pm »
@Brian
The pin I touch with my multimeter is completely unconnected in the design. It's pin K1 and yet it still makes the FPGA start working? Can't remember what mode the multimeter is in but the other probe is just floating on the desk.
https://youtu.be/iCUSLkI50NA
Offline iMo
  • Country: pm
« Reply #23 on: August 23, 2018, 10:01:55 pm »
Am I right?
Double check the programming manual - the R603 should be wired to GND when SPI in slave mode, afaik.
SPI_SS_B:
SPI Slave Select output from the application processor. Active Low. Optionally hold Low prior to configuration using a 10 KOhm pull-down resistor to ground.
« Last Edit: August 23, 2018, 10:03:55 pm by imo »
    • Matt's Projects
« Reply #24 on: August 23, 2018, 10:12:52 pm »
Am I right?
Double check the programming manual - the R603 should be pulled to GND when SPI in slave mode, afaik.
SPI_SS_B:
Fair observation, however the pull-up needs to be there because later I will add an external flash. The programmer pulls the SS_Prog line low during programming to force it into slave spi mode and then brings it high again. Nonetheless, it was worth a try and I connected SS_PROG to ground instead of to the programmer - it still programmed and the same end result.
From the Programming and Configuration guide:
"The optional 10 KOhm pull-down resistor on the SPI_SS_B signal ensures that the iCE40 FPGA powers up in the
SPI peripheral mode. Optionally, the application processor drives the SPI_SS_B pin Low when CRESET_B is
released, forcing the iCE40 FPGA into SPI peripheral mode."
In this case, the application processor is the FT2232H
« Last Edit: August 23, 2018, 10:14:30 pm by MattHollands »
