Hi.
Won't these two circuits work exactly the same to control a motor using a microcontroller or a Raspberry?. I don't understand the need to use two NPN transistors, when apparently just one NPN and the MOSFET would be enough.
In my case, the load will be an electromagnet at 50v DC, so I don't know if using the circuit with a single NPN, the base resistor R1 of Q1 would have to be increased or the 100K resistor would be the same. Or is there any advantage to using the circuit with two NPN transistors and the MOSFET.
