hi guys
i have bought
this board
here it is the schematic
the onboard
RS232-adapter is damaged (the TX is not working)
so i have removed all the jumpers (on the jp9 connector) which connect the maxim chip to fpga pins, and i wired to external RS232 adaptor (3.3V, 5V tolerant, powered by the fpga regulator at 3.3V).
i have put a 6809 SoC on bram (with SYSD9BUG v1.4 inside) and i have connect an uart cable to my PC
the problem is: it seems there is something which resets the SoC with cause uncommon behavior on the hyper terminal, i see this
SYSD9BUG v1.4 FOR S3E
> WHAT?
> WHAT?
> WHAT?
> WHAT?
that means that the SoC has been reseted several times
The same (VHDL) code has been synthesized for Digilent s3e-500-ug320 (instead of s3e-500-
pg208 of the sparkfun board), and i see this on bootstrap
I checked the PowerSupply, 5V,1A, and it is low ripple, also the sparkfun has an onboard regulator that should filter residual noises on Vin
What could be wrong ?
should i investigate about the constraints, the hardware, the HDL ?
any suggestion is welcome
