Author Topic: XC8 - how can I pass bits to and from a function  (Read 12369 times)
Offline DeltaTopic starter
Re: XC8 - how can I pass bits to and from a function
« Reply #25 on: November 10, 2015, 07:06:35 pm »
Just to add, I am fully aware that the code I am writing is going to be shite, however at this stage into my foray with C, I'm deliberately writing code that I can easily follow and understand.  I don't mean to sound rude or react badly to criticism, but I'm just trying to keep it simple for now.
Online Ian.M
« Reply #26 on: November 10, 2015, 07:49:08 pm »
No problem.  Exploring simple code and eventually more complex code and the far corners of the ANSI C language and specific compiler implementation is how you learn.  If you try to jump straight to the top of the learning curve, you'll be likely to end up as a cargo cult coder!  :(
However, I'd do something like this:
Caution: Air code warning! ;) I've just thrown this together on the fly so I can freely disclose it. It should compile OK as part of a full program, unless I've made a typo.
// From Jack Ganssle's Example 3 debouncing algorithm
// See page 2 of: http://www.ganssle.com/debouncing.htm
// with actual debouncing extracted to main program for efficiency
#define MAX_CHECKS 10 // # checks before a switch is debounced
uint8_t Debounced_State=0,Old_Debounced_State; // Current and previous debounced
                                               // state of the switches.
volatile uint8_t State[MAX_CHECKS]; // Array that maintains bounce status
// Service routine called by a timer interrupt
void DebounceSwitch()
       static uint8_t Index; // Persistent pointer into State
       State[Index++]=~PORTA; // All switches active low on Port A.
                              // Leave out ~ for active high
       if(Index>=MAX_CHECKS) Index=0;
// Routine to debounce all keys
void DebounceSwitches()
       uint8_t i,j;
       Old_Debounced_State=Debounced_State;
       j=0xff;
       for(i=0; i<MAX_CHECKS;i++)
          j=j & State[i];
       Debounced_State= j;
// Macro to read Switch N where N is the bit number. Returns TRUE if pressed.
#define ReadSwitch(n) (!!(Debounced_State & 1<<n))
// Macro to read if Switch N has just been pressed.  Returns True if newly pressed.
#define ReadNewSwitch(n) (!!((Debounced_State^Old_Debounced_State) & Debounced_State & 1<<n))
//Usage:
#if 0  //Don't compile sample usage, its only a snippet!
   DebounceSwitches();  'freshen' the debounceed state, call this ONCE in your current polling loop.
   if(ReadSwitch(0))  // used as a shift key so want pressed state, not newly pressed state
         if(ReadNewSwitch(1)) { /* Shifted Key1 routine */ }
         if(ReadNewSwitch(2)) { /* Shifted Key2 routine */ }
      } else {
         if(ReadNewSwitch(1)) { /* Key1 routine */ }
         if(ReadNewSwitch(2)) { /* Key2 routine */ }
#endif
It can easily be extended for 16 switches and it isn't too tricky to extend it to scan and debounce a 16 key 4x4 matrix.
I'm no C guru. If I ever look like one its because I'm  standing on the shoulder of giants.
« Last Edit: November 10, 2015, 08:05:31 pm by Ian.M »
