Author Topic: Year 2038 bug - how big an issue will it be?  (Read 5693 times)
Offline n5al
  • Country: mx
Re: Year 2038 bug - how big an issue will it be?
« Reply #25 on: January 30, 2022, 03:57:26 am »
Changing the "time_t" parameter from 32 to 64 bits doesn't really solve the year 2038 roll-over problem.  It just postpones it for 292 billion years, when we will undoubtedly have to address this issue once again!  :)
« Last Edit: January 30, 2022, 04:00:16 am by n5al »
The following users thanked this post: boz, I wanted a rude username
Offline brucehoult
« Reply #26 on: January 30, 2022, 06:03:03 am »
To be fair, that's 50 times longer than our Sun will exist for.
Offline wek
  • Country: sk
« Reply #27 on: January 30, 2022, 09:58:25 am »
Speaking of practical solutions, it would be enough if the existing <time.h> variables/functions would be defined with a user-selectable epoch in mind. Adjusting to different epochs is a trivial typecast/addition/subtraction.
Rationale here is, that the vast majority of embedded systems (which is the vast majority of applications using C/<time.h> today) seldom need to look at time  before their conception. This (together with rigorous use of uint32_t) would give them >100 years of effective lifetime, together with effective use of 32-bit arithmetics.
OTOH, merely increasing time_t to 64-bits in itself may not solve the problem as there may still be arithmetics issues lurking around (see mktime() issue in newlib, but similar may occur in user code, too).
Btw. you may also want to look at how year is calculated in current incarnation of newlib's mktime()...
JW
Offline SiliconWizard
« Reply #28 on: January 30, 2022, 05:26:30 pm »
Indeed. ;D
But switch to a 1-µs resolution, and suddenly... =)
Offline nctnico
« Reply #29 on: January 30, 2022, 06:09:10 pm »
Indeed. ;D
Or 1 femto second. Yes, that is a real problem for a project I'm working on; not a hypothetical what-if. Having support for 128 bit integers would be great.
« Reply #30 on: January 30, 2022, 06:26:26 pm »
Indeed. ;D
Dunno what language(s) you use, but you can always roll your own. Not too hard.
And, as I suggested earlier, if you really don't want to limit the width, you can use arbitrary-precision arithmetic - GNU GMP works really well, and is an option unless the added code size is too much.
It's "interesting" to notice that current major C (and so I guess C++) compilers don't seem to support 128-bit integers (at least last time I checked, and at least using the standard types), even the ones that produce 64-bit code (while the ones that produce 32-bit code do support 64-bit integers!) GCC supports it as an extension, but only for targets that have native 128-bit operations: the https://gcc.gnu.org/onlinedocs/gcc/_005f_005fint128.html - whereas, as I just said, "emulated" 64-bit is no problem using (u)int64_t and siblings, on 32-bit targets. Go figure... :palm:
Offline brucehoult
« Reply #31 on: January 30, 2022, 09:40:10 pm »
"gcc" (which is really Apple LLVM) on my M1 Mac does __int128 ok. No such thing as int128_t though :-(
#define big __int128
big add(big a, big b){
  return a + b;
       0: 40 00 00 ab                  adds x0, x2, x0
       4: 61 00 01 ba                  adcs x1, x3, x1
       8: c0 03 5f d6                  ret
So does actual gcc for riscv64:
0000000000000000 <add>:
   0:   87aa                    mv      a5,a0
   2:   9532                    add     a0,a0,a2
   4:   00f537b3                sltu    a5,a0,a5
   8:   95b6                    add     a1,a1,a3
   a:   95be                    add     a1,a1,a5
   c:   8082                    ret
But it's not supported for riscv32 :-(
Of course you can implement it yourself in pure C using the same technique as riscv64 does:
#include <stdint.h>
struct int128 {uint64_t hi; uint64_t lo;};
struct int128 bar(struct int128 a, struct int128 b){
  struct int128 r;
  r.lo = a.lo + b.lo;
  r.hi = a.hi + b.hi + (r.lo < a.lo);
  return r;
That will work fine on both 32 bit and 64 bit machines, though of course it will make quite a bit of code on a 32 bit machine!
On the M1, LLVM doesn't realise it can use the carry flag, but it doesn't matter too much:
0000000000000000 ltmp0:
       0: 61 00 01 ab                   adds    x1, x3, x1
       4: 48 00 00 8b                   add     x8, x2, x0
       8: 00 35 88 9a                   cinc    x0, x8, hs
       c: c0 03 5f d6                   ret
But gcc on Ubuntu amd64 realises it can use the carry flag:
0000000000000000 <bar>:
   0:   f3 0f 1e fa             endbr64
   4:   48 89 d0                mov    %rdx,%rax
   7:   48 01 ce                add    %rcx,%rsi
   a:   48 89 f2                mov    %rsi,%rdx
   d:   48 11 f8                adc    %rdi,%rax
  10:   c3                      retq
Ooooo .. shiny new Control Flow Integrity instruction!
« Last Edit: January 30, 2022, 09:56:05 pm by brucehoult »
« Reply #32 on: January 31, 2022, 02:32:46 am »
Yes, as quoted from gcc's docs, __int128/__uint128 is a purely gcc extension (likely supported by LLVM and other compilers) that is only supported on targets that have native 128-bit operations...
I suppose this all comes from the fact that the C std still does not *mandate* (but of course allows!) integer widths larger than 64 bits. So while implementations can absolutely define much wider integers, they do not *have* to provide, for instance, int128_t. But why gcc maintainers have chosen not to define int128_t as __int128, I have no clue. It wouldn't be non-conforming to the std as far as I know! Maybe that's just due to the fact that since it's not *mandated* to support it, they chose not to define the equivalent stdint type, in order for users not to expect having it supported on other compilers... maybe. And, the fact they chose not to even define a 128-bit type (even as an extension) for 32-bit targets is a mystery. Just again likely to be rooted in the "ought to be enough" syndrom.
As a side note regarding C - a related issue is that, while the std allows stdint's > 64 bits (but allows them of course), it does not define any integer type that could map to a 128 -bit integer - at least if the implementation supports all fixed-widths from 8-bit to 64-bit (which is the usual) - because stdint.h is currently nothing more than implementation-specific macros that map to the standard 'int', 'long int', 'long long int'... but I don't think you can add more 'long' qualifiers to the party (or can you?) Well, this is the part of C that still severely bites. =)
Offline brucehoult
« Reply #33 on: January 31, 2022, 02:49:10 am »
NONE of the ISAs I showed code for -- amd64, arm64, and riscv64 -- have native 128-bit operations.
All of them implement __int128 by doing multiple operations with 64 bit ints.
There is absolutely nothing to prevent you implementing __int128 operations using 32 bit operations -- it just takes more of them.
Compiling the code I showed (function bar) on any 32 bit platform will do exactly that.
#include <stdint.h>
  struct int128 r;
  r.lo = a.lo + b.lo;
  return r;
For example, here's the result on arm32 (implementing a 128 bit add using C on a 32 bit machine)
00000000 <bar>:
   0:   b082            sub     sp, #8
   2:   e92d 03f0       stmdb   sp!, {r4, r5, r6, r7, r8, r9}
   6:   a906            add     r1, sp, #24
   8:   e881 000c       stmia.w r1, {r2, r3}
   c:   e9dd 2308       ldrd    r2, r3, [sp, #32]
  10:   990c            ldr     r1, [sp, #48]   ; 0x30
  12:   1854            adds    r4, r2, r1
  14:   990d            ldr     r1, [sp, #52]   ; 0x34
  16:   eb43 0501       adc.w   r5, r3, r1
  1a:   9906            ldr     r1, [sp, #24]
  1c:   9e0a            ldr     r6, [sp, #40]   ; 0x28
  1e:   eb11 0806       adds.w  r8, r1, r6
  22:   9e07            ldr     r6, [sp, #28]
  24:   990b            ldr     r1, [sp, #44]   ; 0x2c
  26:   eb46 0901       adc.w   r9, r6, r1
  2a:   429d            cmp     r5, r3
  2c:   bf08            it      eq
  2e:   4294            cmpeq   r4, r2
  30:   bf34            ite     cc
  32:   2301            movcc   r3, #1
  34:   2300            movcs   r3, #0
  36:   eb18 0803       adds.w  r8, r8, r3
  3a:   f149 0900       adc.w   r9, r9, #0
  3e:   e9c0 8900       strd    r8, r9, [r0]
  42:   e9c0 4502       strd    r4, r5, [r0, #8]
  46:   e8bd 03f0       ldmia.w sp!, {r4, r5, r6, r7, r8, r9}
  4a:   b002            add     sp, #8
  4c:   4770            bx      lr
Or riscv32...
00000000 <bar>:
   0:   0085ae03                lw      t3,8(a1)
   4:   00c5a303                lw      t1,12(a1)
   8:   00862683                lw      a3,8(a2)
   c:   00c62783                lw      a5,12(a2)
  10:   00de06b3                add     a3,t3,a3
  14:   01c6b833                sltu    a6,a3,t3
  18:   00f307b3                add     a5,t1,a5
  1c:   00f80833                add     a6,a6,a5
  20:   0005a883                lw      a7,0(a1)
  24:   0045a703                lw      a4,4(a1)
  28:   00062783                lw      a5,0(a2)
  2c:   00462603                lw      a2,4(a2)
  30:   00f887b3                add     a5,a7,a5
  34:   0117b8b3                sltu    a7,a5,a7
  38:   00c70733                add     a4,a4,a2
  3c:   00e88733                add     a4,a7,a4
  40:   00100613                li      a2,1
  44:   00000593                li      a1,0
  48:   00686863                bltu    a6,t1,58 <.L2>
  4c:   03030863                beq     t1,a6,7c <.L4>
00000050 <.L3>:
  50:   00000613                li      a2,0
  54:   00000593                li      a1,0
00000058 <.L2>:
  58:   00c78633                add     a2,a5,a2
  5c:   00f637b3                sltu    a5,a2,a5
  60:   00b70733                add     a4,a4,a1
  64:   00e787b3                add     a5,a5,a4
  68:   00c52023                sw      a2,0(a0)
  6c:   00f52223                sw      a5,4(a0)
  70:   00d52423                sw      a3,8(a0)
  74:   01052623                sw      a6,12(a0)
  78:   00008067                ret
0000007c <.L4>:
  7c:   fdc6eee3                bltu    a3,t3,58 <.L2>
  80:   fd1ff06f                j       50 <.L3>
This takes a few more arithmetic operations than on a 64 bit machine, but most of the extra code is loading the arguments from RAM and storing the result in RAM as the ABIs don't have any way to pass arguments the size of four registers in registers.
The following users thanked this post: Pineapple Dan
Offline Pineapple Dan
  • Country: ie
« Reply #34 on: January 31, 2022, 09:24:40 pm »
I think this will be BIG.
For embedded systems, it will be bigger than Y2K whose actual effects were outside the embedded world.
And another with GPS, though I would hope currently working units will have coded around it.
https://en.wikipedia.org/wiki/GPS_week_number_rollover
I have an old Garmin GPS 12 that is affected by this. Didn't know about the rollover problem until one day I switched it on and it told me I was in 1997
Offline brucehoult
« Reply #35 on: January 31, 2022, 09:35:59 pm »
My first two GPS's have been through two date rollovers now!
My oldest I've have since 1994
1397738-0
(the big guy on bottom left)
« Reply #36 on: January 31, 2022, 10:16:01 pm »
Oh, I know. I was just deriving the point from gcc's docs (that I linked). Admittedly, the paragraph on 128-bit integers is not crystal clear.
So just some guesses here - since I don't know exactly what led to those decisions:
- Regarding amd64: strictly speaking you're right, but actual x86_64 processors (Intel, AMD) have had some 128-bit registers for a pretty long time now (through extensions mainly), so my guess it that gcc first added 128-bit integer support for those targets, hence the "explanation" made in the linked paragraph;
- Then probably many people using other 64-bit targets (or plain amd64 without extensions) asked for support of 128-bit integers too, and not adding that support for those would have looked like unacceptable bias towards specific targets (albeit very common ones) - so they added this using software emulation;
- For the record, as I remember, 128-bit integers were also supported as an extension in MSVC a "long" time ago, so that may have also been part of the trigger regarding x86_64 targets;
- For 32-bit targets, as I said, there was probably very little demand in comparison, so they just didn't bother;
- Also as I mentioned, since widths > 64 bits are not *required* to be implemented (from the std), there is no incentive for generalizing this implementation for all targets.
Again, just guesses here, but the most "reasonable" I can come up with, given the information I have about this.
Maybe the real rationale is a bit different and more "political" than this, or due to a number of constraints in the compiler design, I dunno.
Offline brucehoult
« Reply #37 on: January 31, 2022, 10:27:22 pm »
What registers would those be?
If you mean SSE, those are for SIMD, they support parallel operations on data from 8 to 64 bits in size. They don't support 128 bit arithmetic.
Offline NiHaoMike
    • Facebook Page
« Reply #38 on: February 02, 2022, 02:07:28 am »
There was a short-lived TV animated program about Dilbert, that was often more angry and grim than the daily newspaper comic strip.
Back when Y2K was an issue, their treatment of the problem was to show Wally in 1975, when he was still an enthusiastic young engineer just starting at the company.  The older employees showed him that they used only two digits to encode the year.  He asked, "won't that be a problem in 25 years?", and they laughed at him.
The game Detroit: Become Human is set in the year 2038 as a similar reference to the problem.
Online Ed.Kloonk
  • Cat video aficionado
« Reply #39 on: February 02, 2022, 02:29:43 am »
Lemme guess. Game stops working after 2038?
 :scared:
The ultimate Easter egg.
iratus parum formica
Offline Renate
« Reply #40 on: February 02, 2022, 07:31:34 pm »
Some of us just laugh at 2038 bugs. We'll be dead by then. :-DD
The following users thanked this post: Ed.Kloonk
Offline TimFox
« Reply #41 on: February 02, 2022, 07:42:53 pm »
Yes, Wally's senior colleagues in 1975:  most of them dead now (47 years later) and the rest no longer interested in industrial software.
« Reply #42 on: February 02, 2022, 08:19:34 pm »
Yes, the xmm registers. SSE grows in each new generation, so I don't even know what kind of instructions there are in the latest ones, but there sure is a lot of them. While none seems to directly allow basic 128-bit arithmetic such as addition and subtraction of two 128-bit integers, there are of course the logic operations (bitwise) who do. And, I've seen a few instructions that can do some fancy operations on several 8-bit to 64-bit pieces and yield a single result on 128-bit... so, you tell me if that counts as 128-bit arithmetic or not... but if you want to issue a single addition or subtraction of 128-bit numbers, then, right, that's a no. (At least as of yet, and that I know of...)
Oh, and 128-bit xmm registers were also available in 32-bit mode IIRC, so...
But we're digressing. All I was doing is making some hypothesis (which sounded reasonable, at least to me), based on this point in gcc's docs:
As an extension the integer scalar type __int128 is supported for targets which have an integer mode wide enough to hold 128 bits.
So, do the x86 xmm registers fit this description? Go figure. Was the x86 the first target getting __int128 support in gcc? That's my take here, but I don't know for sure (and if so, why in 64-bit mode only?). Finally, what does the above sentence really mean? We possibly need a PhD in gcclogy to make full sense of it.
But if anyone having been part of the decision process for this can chime in - which is likely to never happen - to explain the real rationale behind the choice of implementing __int128 only on 64-bit targets (and maybe not even all of them, I haven't checked)...
Offline brucehoult
« Reply #43 on: February 02, 2022, 09:28:39 pm »
I think that statement is simply wrong and/or outdated rather than needing to be parsed correctly.
If the maintainers of avr-gcc decide to implement and commit support for 64 and 128 bit integers on their 8 bit CPU, is someone really going to tell them they can't upstream it because "the docs say we only support __int128 on targets with native support for it"?
(AVR can *just*, using every one of its thirty two 8 bit registers, hold two 128 bit integers in registers at the same time. Not very practical. But you could implement a 128 bit accumulator using 16 registers and implement operations between that and RAM. That's still better than making 128 bit arithmetic purely RAM-to-RAM like all other 8 and 16 bit CPUs I can think of need to do)
Offline peter-hTopic starter
« Reply #44 on: February 04, 2022, 12:10:55 pm »
This is getting way off topic but surely a compiler can transparently implement any data type. 128 bit ints are easy. In years past, we even had BCD floats (for accountancy and such).
Online Siwastaja
« Reply #45 on: February 04, 2022, 02:19:23 pm »
Of course it's trivial. The question is why they don't do that. It's not mandated by the C standard, so you could argue that not having optional features forces people write more portable code, i.e., implement any such feature themselves.
Yet codebases are actually full of compiler-specific stuff and I'm all for that. Just-In-Time works here: try to make it portable within sensible limits, but don't waste too much time on that, do that only when you actually need to port it. Chances are, the "compiler-specific" feature after all exists on the target compiler, even if it didn't when you started the job. At the end of the day, this tends to lead into standardization of commonly used patterns.
I would also like to see types like uint24_t or uint96_t which make sense on 8-bit and 32-bit architectures, respectively. But of course we can't have everything. 128-bit types would be actually useful.
And that would actually be one step towards arbitrary length bit array. It's not one or two times I use uint64_t not to represent large numbers, but to represent a 8-byte buffer. I can shift bits in and out, mask bits out of it, and compare the whole buffer with ==, <, >, != and so on. This strategy as it stands only works with 8, 16, 32 and 64-bit buffers. For everything else, you need to write buffer handling code.
« Last Edit: February 04, 2022, 02:23:07 pm by Siwastaja »
Offline bson
« Reply #46 on: February 04, 2022, 04:58:24 pm »
stdint.h is defined by POSIX: https://pubs.opengroup.org/onlinepubs/9699919799/basedefs/stdint.h.html
gcc implements its builtin types using a __ prefix, then stdint.h isn't much more than a set of typedefs to expose them.  There is no typedef for int128_t presumably because POSIX hasn't required one.  But it does look like it should be permissible to define other types supported by a compiler as long as it follows the same pattern.
« Last Edit: February 04, 2022, 05:00:35 pm by bson »
« Reply #47 on: February 04, 2022, 07:34:14 pm »
Don't confuse POSIX with the C standard. Those are two different things. And stdint.h is a C standard thing since C99, that is over two decades ago. The std defines those new "types" without imposing a limit AFAIR. But it just *requires* implementations to support at least up to 64 bits. The rest is up to the implementation. It's certainly not a violation to define int128_t, or even int256_t, or whatever.
As to gcc's rationale here, again here nobody knows. I guess some people among gcc maintainers do.
There's something from the standard that kind of "promotes" implementing this as extensions though: the std defines the stdint integers through the inclusion of 'stdint.h', the corresponding types (such as intxx_t...) NOT being keywords of the language. So it's quite logical that compilers would either use the std keywords (such as char, short, int, etc...) for defining stdint integers, or use some proprietary extensions. No choice here. Now why they didn't map the __int128 extension to int128_t in stdint.h, that's a bit puzzling. As we said, maybe that was to avoid people thinking using this type would be portable, but no such thing is said in the standard itself.
As to 32-bit targets, I guess you gotta draw the line somewhere when it comes to non-mandatory features, and this is likely the main point. Sure they could have implemented 128-bit integers for 32-bit targets. But now some people may ask for 256-bit integers. And so on...
And sure it's not hard to hand-implement them anyway, so back to the topic somewhat, not having 128-bit integers (or any other width) supported is certainly no good excuse for not using them if required by some application. Just implementing addition and subtraction (you usually don't need anything else for time stuff?) would take about a couple minutes of development time (if you don't already have that kind of code ready!) - would it be worth saving a few minutes of dev time and end up with an application that would just be a time bomb?
But anyway - as always, this kind of limitations in software mostly comes from 3 things IMO: laziness from developers (that happens), lack of foresight (happens a lot too), or planned obsolescence (adding limits in software is an excellent way of forcing users to upgrade.)
Online Siwastaja
« Reply #48 on: February 05, 2022, 11:44:07 am »
IMHO, they just define int128_t in stdint.h.
It might cause a few unhappy campers with a small portability surprise, but as a whole, it would drive the C language in good direction. And I'm sure other compilers would follow. Except those who never follow, or even support stadard C99.
Offline bson
« Reply #49 on: February 05, 2022, 08:25:25 pm »
Yeah, but the POSIX standard is more recent and has some useful additions, like ptrdiff_t.
