MAX 7000 device outputs can be programmed to meet a variety ofsystem-level requirements.MultiVolt I/O InterfaceMAX 7000 devices—except 44-pin devices—support the MultiVolt I/Ointerface feature, which allows MAX 7000 devices to interface withsystems that have differing supply voltages. The 5.0-V devices in allpackages can be set for 3.3-V or 5.0-V I/O pin operation. These deviceshave one set of VCC pins for internal operation and input buffers(VCCINT), and another set for I/O output drivers (VCCIO).The VCCINT pins must always be connected to a 5.0-V power supply.With a 5.0-V VCCINT level, input voltage thresholds are at TTL levels, andare therefore compatible with both 3.3-V and 5.0-V inputs.The VCCIO pins can be connected to either a 3.3-V or a 5.0-V powersupply, depending on the output requirements. When the VCCIO pins areconnected to a 5.0-V supply, the output levels are compatible with 5.0-Vsystems. When VCCIO is connected to a 3.3-V supply, the output high is3.3 V and is therefore compatible with 3.3-V or 5.0-V systems. Devicesoperating with VCCIO levels lower than 4.75 V incur a nominally greatertiming delay of tOD2 instead of tOD1.Open-Drain Output Option (MAX 7000S Devices Only)MAX 7000S devices provide an optional open-drain (functionallyequivalent to open-collector) output for each I/O pin. This open-drainoutput enables the device to provide system-level control signals (e.g.,interrupt and write enable signals) that can be asserted by any of severaldevices. It can also provide an additional wired-OR plane.Altera Corporation 21MAX 7000 Programmable Logic Device Family Data SheetBy using an external 5.0-V pull-up resistor, output pins on MAX7000S devices can be set to meet 5.0-V CMOS input voltages. WhenVCCIO is 3.3 V, setting the open drain option will turn off the outputpull-up transistor, allowing the external pull-up resistor to pull theoutput high enough to meet 5.0-V CMOS input voltages. WhenVCCIO is 5.0 V, setting the output drain option is not necessarybecause the pull-up transistor will already turn off when the pinexceeds approximately 3.8 V, allowing the external pull-up resistor topull the output high enough to meet 5.0-V CMOS input voltages.Slew-Rate ControlThe output buffer for each MAX 7000E and MAX 7000S I/O pin hasan adjustable output slew rate that can be configured for low-noiseor high-speed performance. A faster slew rate provides high-speedtransitions for high-performance systems. However, these fasttransitions may introduce noise transients into the system. A slowslew rate reduces system noise, but adds a nominal delay of 4 to 5 ns.In MAX 7000E devices, when the Turbo Bit is turned off, the slewrate is set for low noise performance. For MAX 7000S devices, eachI/O pin has an individual EEPROM bit that controls the slew rate,allowing designers to specify the slew rate on a pin-by-pin basis.
It seems I have conflicting datasheets maybe. I am confused now. below is the datasheet I have been working from.https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ds/m7000a.pdf
