Author Topic: Cat 6 cable stopped working, sort of.  (Read 1117 times)
Offline connectTekTopic starter
« on: February 16, 2023, 04:31:24 am »
I had a customer call me that his internet had stopped working in his shed. I did not do original install. It was working previously as I had added an Acces point to it.
The cable is a cat 6, underground about 60m( in conduit).
I do a continuity test, no problem, I do a cable length test, 220m ,WTF!
Now, I connected to my laptop, I  it works fine, no problem,  YET when I plug it back into the switch, ( on the shed side) no go.
I changed switch in the shed and even the modem in the house.
I'm stumped.
Any help would be much appreciated.
« Last Edit: February 16, 2023, 04:34:29 am by connectTek »
Offline james_s
Re: Cat 6 cable stopped working, sort of.
« Reply #1 on: February 16, 2023, 04:44:35 am »
Have you tested it for signal integrity with a cable tester? Is it rated for underground use? It's pretty likely that the conduit is filled with water submerging the cable. It's also possible the problem was with the termination on one of the ends.
Offline Halcyon
  • Global Moderator
« Reply #2 on: February 16, 2023, 05:03:44 am »
Yeh sounds like possibly corrosion or something is impacting the cable integrity. Rather than trying to troubleshoot, it'll probably be easier to replace it with a new length cable (or fibre).
Offline MrMobodies
« Reply #3 on: February 16, 2023, 05:35:25 am »
Did you do a flame test on the conductors?
Online jonpaul
« Reply #4 on: February 16, 2023, 05:41:29 am »
Of the 4 pairs, one is either poor connection, corroded eg at RJ-45 crimp connector, or dirt, corrosion creating a leakage paths to earth or another pair.
Ger an Ethernet cable checker, or
just Short the four  far end pairs togather
Check resistance  at the four near end pairs.
Use wire table at correct L and AWG to find loop resistance
Bon chance
Jon
Jean-Paul (EE 1968, the Internet Dinosaur)
« Reply #5 on: February 16, 2023, 11:43:56 am »
I have re terminated both ends.
Yet when I directly connect my laptop it works fine, full speed ,no problems. It just doesn't work when connecting to a switch, of which I have replaced.
Offline Psi
« Reply #6 on: February 16, 2023, 12:25:04 pm »
When you exceed the length spec odd things like that can happen, sometimes it will work and sometimes it wont.
Now I doubt it actually is 220m long, but that is a sign of something seriously wrong with the cable.
One question though, are you sure your laptop is trying to use the cable at the same speed as the switch?
 1gig, 10gig 2.5gig etc.
Offline JohanH
« Reply #7 on: February 16, 2023, 12:46:54 pm »
It happened once that the local electronics shop had to send back their rolls of CAT6 cable to the importer when someone found out that the cable didn't actually work for longer lengths than 30 m or so. Continuity check was OK, but no devices wanted to negotiate after a certain length. So the cable was bad quality.
But it's odd that it works with the laptop, but not the switch. Possible that the network card in the laptop is more forgiving?
« Reply #8 on: February 16, 2023, 05:40:21 pm »
Thanks guys.
Will pull new cable next week.
Will update on what I find.
Cheers
Online jonpaul
« Reply #9 on: February 17, 2023, 01:32:23 am »
A lot of Ethernet cable made,in China is non-compliance to the IEEE and IEC,specs.
Suggest you buy only Belden CAT 6, etc.
See Belden site for attenuation, phase, abberation per m legnth and vs freq.
Jon
Offline py-bb
  • Country: af
« Reply #10 on: April 03, 2023, 09:46:01 am »
I'm stumped.
I've got a damaged cable - one of the pairs got nicked (at least) in a single spot. Anyway it will ONLY work between NetGear switches, so you can have situations where devices connect but other devices wont.
This is all I have to offer sorry.
Online wraper
  • Country: lv
« Reply #11 on: April 03, 2023, 10:03:52 am »
Some devices are more tolerant to bad or too long cables than others. Nothing that surprising here. Also did you check in what mode it works, I would expect 100Mbit which uses only half of twisted pairs.
Offline sokoloff
« Reply #12 on: April 03, 2023, 11:11:37 am »
An underground conduit is a wet location. I ran fiber through mine to the garage to avoid continually replacing a dry-rated cable or chasing down 30 meters of gel-filled Cat-6 (and dealing with the mess of that on both ends).
Offline bitwelder
« Reply #13 on: April 03, 2023, 11:50:04 am »
Depending on the switch where the cable is plugged, there might be an option to check 'cable-diagnostics' which can also tell you for each twisted pair
whether it's OK (from its point of view) and even the approximate length.
« Reply #14 on: May 14, 2023, 08:13:01 am »
I have installed a wireless link, problem solved.
Thanks guys.
Offline BTO
« Reply #15 on: May 15, 2023, 02:41:47 pm »
OK, I DO THIS FOR A LIVING AND I'M VERY GOOD AT IT
1. This comes down to what testing equipment you have and where your knowledge is at on this subject
2. Re this
"I do a continuity test, no problem, I do a cable length test, 220m ,WTF!"
WTF.. Easy !!
Firstly what does "No Problem" Mean ?
I know what the general consensus is , but many a time have i seen a tech that said "No problem" and there was a problem.
More specifically, you mean "No problem" In your opinion
Ok. so When you say CONTINUITY TEST do you actually mean a continuity test or was it a resistance test or did you use
a Basic $20 network tester ?
In any case, Continuity testing only gives you part of the picture , and it's only a basic test
HENCE WHY YOU GOT THE PROBLEM
you apparently know the cable is 60m  (The Max Segment length, by the book is 100metres)
so when you say Cable Length test, do you mean T.D.R. ? (Time Domain Reflectometry)
if so... you are getting the result of a longer cable because ... the way TDR Works is, it sends a signal down a cable (you need to enter
the AWG setting for the cable diameter and type) THIS COULD BE ONE ISSUE, It sends a signal at a known VOP (Velocity of Propogation)
and when it hits an open or other fault a reflection is created that travels back to the source
The meter measures the time taken, Divided by 2 (to give the one way cable length)
The signal was attenuated as a result of RESISTANCE on the cable (likely you have a bad joint, Rusted or Corroded cable
and one of the pairs is broken but just barely hanging on
You want to do a WIREMAP TEST (with a tester that gives cable length readings on all pairs)
all pairs should be approx equal length (but not exact)
Another thing you could do is this...
since it's a 4 Pair UTP
(this is the cheap way around  the problem)
Get a multimeter, Test it with a known resistor in resistance mode for accuracy
Go to one end of the cable, Chop off the connector and short the pairs
short Blue to Blue/White
Short Orange to Orange/White
short Green to Green/White
Short Brown to Brown/White
but not to each other
Now go to the other end, crack out your multimeter and check the loop resistances
on a 20 metre cable you should expect to have less than 5 Ohms resistance
check each pair to see which pair has the high resistance,  it's likely you'll find at least one
let me know how you go
UPDATE :
ahh i see you found the problem
Damaged Cable
let's always remember out basics shall we
OSI MODEL
Layer 1 Problem (Physical layer) - aka  Nicked Cable
therefore causing a non optimal connection
THUS LEADING US TO OHM'S LAW
Causing INCREASED RESISTANCE
Which in turn explains your 220m TDR Reading
Always remember
short all the pairs on the end to the corresponding white wire
test the resistance on the other end
ALWAYS REMEMBER THE BASICS,  they really do save you time
« Last Edit: May 15, 2023, 02:46:02 pm by BTO »
QUESTION EVERYTHING!!!
Offline David_AVD
« Reply #16 on: May 15, 2023, 10:21:08 pm »
Split pairs can also be a problem. The cheap testers won't discover that as the pin 1..8 still go to 1..8 , just not in the correct pairing.
