Author Topic: find downloadable files in partial link  (Read 1011 times)
Offline Zeyneb
« on: June 10, 2022, 11:24:06 pm »
Hi there,
Maybe an actual example is the best way to communicate what I'm aiming for.
When you look up the following Eevblog forum post:
https://www.eevblog.com/forum/microcontrollers/fujitsu-f2mc-8fx-f118as-firmware-extraction-help/msg1400822/#msg1400822
you can see the user abyrvalg post links to the Fujitsu website, for example:
http://www.fujitsu.com/downloads/MICRO/fma/mcu/PCW8FXe.pdf
These links do work and provide the correct documents. However when I go to www.fujitsu.com to find a datasheet for a related microcontroller, the MB89023. I'm not getting results.
So, I was wondering how I could explore this url-folder thing:
for available files?
I tried to install some tools like Simple Mass downloader or JDownloader 2 but I'm not getting this to work.
Thanks for any help in advance.
goto considered awesome!
Offline Stray Electron
Re: find downloadable files in partial link
« Reply #1 on: June 11, 2022, 03:15:44 pm »
   If you know the filename go to Google and enter the filename followed by site:www.fujitsu.com.  You can also search individual subdirectories on the target site by adding "/subdirectory".
  In your case I would Google "PCW8FXe.pdf site:www.fujitsu.com"  (leave out the "s).
    "PCW8FXe.pdf site:www.fujitsu.com/download" should also work, if the file is still in that sub-directory.
   If you want "MB89023"  search for "MB89023*.*  site:www.fujitsu.com".
« Last Edit: June 11, 2022, 03:18:13 pm by Stray Electron »
Offline Zeyneb
« Reply #2 on: June 11, 2022, 05:30:25 pm »
Thanks, but for this specific case Fujitsu doesn't have that microcontroller part number in their filenames. I found that microcontroller in an Toyota engine ECU. But it seems like its custom build for Toyota and Toyota want to have that datasheet not publicly available.
Yesterday I was looking around on the website evb149 provided me. But I wasn't able to find info on that part number.
Offline mariush
« Reply #3 on: June 11, 2022, 05:34:51 pm »
You can tell google to show results only from one domain / website by adding site:url   after your search words.
So, you could search for :   .pdf site:http://www.fujitsu.com/downloads/MICRO/fma/mcu/
Here, Google gives me 617 results.
