Products => Computers => Networking & Wireless => Topic started by: Zeyneb on June 10, 2022, 11:24:06 pm
Hi there,
Maybe an actual example is the best way to communicate what I'm aiming for.
When you look up the following Eevblog forum post:
https://www.eevblog.com/forum/microcontrollers/fujitsu-f2mc-8fx-f118as-firmware-extraction-help/msg1400822/#msg1400822 (https://www.eevblog.com/forum/microcontrollers/fujitsu-f2mc-8fx-f118as-firmware-extraction-help/msg1400822/#msg1400822)
you can see the user abyrvalg post links to the Fujitsu website, for example:
http://www.fujitsu.com/downloads/MICRO/fma/mcu/PCW8FXe.pdf (http://www.fujitsu.com/downloads/MICRO/fma/mcu/PCW8FXe.pdf)
These links do work and provide the correct documents. However when I go to www.fujitsu.com (http://www.fujitsu.com) to find a datasheet for a related microcontroller, the MB89023. I'm not getting results.
So, I was wondering how I could explore this url-folder thing:
http://www.fujitsu.com/downloads/MICRO/fma/mcu/ (http://www.fujitsu.com/downloads/MICRO/fma/mcu/)
for available files?
I tried to install some tools like Simple Mass downloader or JDownloader 2 but I'm not getting this to work.
Thanks for any help in advance.
If you know the filename go to Google and enter the filename followed by site:www.fujitsu.com. You can also search individual subdirectories on the target site by adding "/subdirectory".
In your case I would Google "PCW8FXe.pdf site:www.fujitsu.com" (leave out the "s).
"PCW8FXe.pdf site:www.fujitsu.com/download" should also work, if the file is still in that sub-directory.
If you want "MB89023" search for "MB89023*.* site:www.fujitsu.com".
Thanks, but for this specific case Fujitsu doesn't have that microcontroller part number in their filenames. I found that microcontroller in an Toyota engine ECU. But it seems like its custom build for Toyota and Toyota want to have that datasheet not publicly available.
Yesterday I was looking around on the website evb149 provided me. But I wasn't able to find info on that part number.
You can tell google to show results only from one domain / website by adding site:url after your search words.
So, you could search for : .pdf site:http://www.fujitsu.com/downloads/MICRO/fma/mcu/
Here, Google gives me 617 results.
