Author Topic: WiFi Monitor for Android with Single Channel METER  (Read 2518 times)
Offline EPAIIITopic starter
« on: May 28, 2022, 09:35:30 am »
I am trying to set up an optimized WiFi in my house, which is somewhat large and shaped like a U so there are extra internal/external walls between the two sides. My WiFi router is located at the rear at the top of one arm of the U. That is both my office and the closest point to the power pole where the optical fiber comes from. I can not change that without a lot of trouble and probably some expense that I would like to avoid.
So I have purchased two Netgear, AC1900 mesh extenders and I need to find the best locations for them, hopefully one in each of the wings will be enough but I can always buy a third or fourth if needed. I had a WiFi monitoring app. in my previous Android cell phone which had a meter screen (round thing with numbers and a dial in the middle). That meter allowed me to walk around and measure the signal strength of a selected WiFi channel and I could select any of the channels that were in range. I can not remember the name of that app.
Can anyone suggest an Android app. that will do this. I already have several loaded and working that have graph style displays, but they take some time to update unlike the meter which only took a second or two.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Online Fraser
Re: WiFi Monitor for Android with Single Channel METER
« Reply #1 on: May 28, 2022, 11:34:14 am »
https://www.netspotapp.com/wifi-analyzer/wifi-analyzer-apps-android.html
Lots do what you are asking for. Google will find them for you if the above link does not help.
Try “Android App Single channel WiFi analyzer”
Fraser
« Last Edit: May 28, 2022, 11:37:24 am by Fraser »
Offline AndyBeez
  • Country: nu
« Reply #2 on: May 28, 2022, 12:14:34 pm »
Did you mean this meter? It's Wifi Analyzer but, I note in the play store the new and improved version has dropped the meter.
Offline gmb42
« Reply #3 on: May 28, 2022, 08:28:23 pm »
In my experience WiFi extenders are a pile of hot garbage.  Mesh systems somewhat less so, but still flaky.
Bite the bullet, run some Ethernet cable and add proper AP's at the building extremities.
« Reply #4 on: May 31, 2022, 02:24:40 am »
Thanks. I have been there and already downloaded a couple of the suggested ones. I guess I need to keep trying until I get one I like.
Fraser
Paul A.  -   SE Texas
« Reply #5 on: May 31, 2022, 02:27:26 am »
That does look a bit familiar. I wonder if I can download an older version.
Thanks!
BTW, I have double checked my old cell phone. I had removed the additional memory card and reformatted it in my new phone. The app I had used is definitely gone.
Paul A.  -   SE Texas
