Author Topic: "SMF cannot connect to database" errors  (Read 5855 times)
    • Mike's Electric Stuff
« on: July 17, 2011, 10:32:42 am »
Been seeing this error  quite a lot in the last week or so.
It tends to come up pretty instantly when it happens.
Usually OK on the  first retry though.
Day Job: Mostly LEDs
Offline EEVblog
Re: "SMF cannot connect to database" errors
« Reply #1 on: July 17, 2011, 11:13:10 am »
I see it occasionally.
No idea of the exact cause, but assuming it's the shared server getting temporarily overloaded.
Dave.
Offline patb
« Reply #2 on: July 17, 2011, 11:37:03 am »
Yeah, same here. I get also page load time-outs from time to time (not so uncommon).
Offline Joshua
« Reply #3 on: July 17, 2011, 06:43:55 pm »
I concur with Mike. I also have had this same message frequently within the last couple of months. It usually goes away on the first refresh as well.
Offline Jimmy
« Reply #4 on: July 18, 2011, 02:40:28 am »
I haven't seen it once on this forum
It may depend on how many connections you can have on the database at any one time as the eevblog forum gets more users there is a better chance someone is using the forum at the exact same time as you.
Offline Chet T16
  • Country: ie
    • Retro-Renault
« Reply #5 on: July 18, 2011, 10:38:29 am »
I've seen this a few times aswell but can't remember ever having a page timeout so it points to something internal between the forum and database.
Is the database on the same server or a different one? My current host uses a different server for databases so no more default 'localhost' in setting up. Generally it works fine but its another variable into the equation when tracking down problems
Chet
Paid Electron Wrestler
Offline EEVblog
« Reply #6 on: July 18, 2011, 11:36:41 am »
The forum is on the same server, using LocalHost
Dave.
Offline Neilm
« Reply #7 on: July 18, 2011, 06:13:38 pm »
Ironically, I got the message when trying to view this.
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline ndictu
  • Country: sk
« Reply #8 on: July 18, 2011, 07:30:12 pm »
Dave: I'm not familiar with SMF but maybe there is an error log somewhere with more info? "Cannot connect" is too vague, could be that the databse doesn't respond to the request at all, or it could actively deny it for some reason.
Also, the database server probably keeps its own logs, maybe you could find something there. Depends on what you are using (MySQL?) and the settings.
It would probably help to know the time so you can search the logs easily, so next time this happens to me I'll post the exact time here. I suggest everyone would do this, a few timestamps should be enough. Also, make sure to use the server time (shown under your name on the top of the page) since it can be a little different from your local time.
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #9 on: July 18, 2011, 09:39:53 pm »
The server has lots of slowdown issues the last 48 Hours,  CPU usage issue again ?
Dave check the logs .  :)
