Author Topic: Animated profile pictures  (Read 6176 times)
Offline ebastlerTopic starter
« on: September 24, 2023, 02:18:07 pm »
Any chance anmiated GIFs could be disabled for use as a profile picture?
Very few users have chosen to use them (thankfully!). But when I come across one while trying to read a thread, I find it quite distracting. See here for example: https://www.eevblog.com/forum/testgear/new-toy()-scope-fnirsi-dpox180h-claimed-180mhz500msps-(may-2023)/msg5074282/#msg5074282
The following users thanked this post: brammus
Online RoGeorge
Re: Animated profile pictures
« Reply #1 on: September 25, 2023, 02:24:57 am »
If not possible, uBlock origin (the Adblocker browser extension) can block certain elements, or certain pictures by pointing at them.  I use that often to block what I don't want.
Another way is to hide avatars entirely, for all users:
https://www.eevblog.com/forum/profile/?area=theme
but only if you are logged in, or to add the user to your ignore list:
https://www.eevblog.com/forum/profile/?area=lists;sa=ignore
such that the entire post, including the animated avatar will not be visible by default.
Offline magic
« Reply #2 on: September 25, 2023, 06:17:47 am »
Right. That's how I deal with the stupid flashing Chinese ad banners here.
Online Psi
« Reply #3 on: September 25, 2023, 07:07:09 am »
You do realize that by making this thread and calling attention to the fact that you can have animated profile pictures you have likely prompted more people to make them.
Online Nominal Animal
« Reply #4 on: September 25, 2023, 08:42:42 am »
I already have two animated avatars here blocked using uBlock Origin.  It's quick to do, so as long as it does not suddenly become more popular, I'll just keep doing that.
I'm not sure if it is worth the effort to ensure nobody uses animated avatars, but it sure would be nice if Dave and the moderators decided and told the members animated avatars are undesirable... but I don't think they care, because the animations don't bother them enough.
Offline magic
« Reply #5 on: September 25, 2023, 01:20:35 pm »
Not sure if it's possible anymore.
Ordinary image attachments are certainly mangled by the forum, and this breaks animated GIFs.
Maybe I should try, purely for science >:D
edit
Yep, I can upload a GIF avatar but the damn thing isn't moving :--
That being said, I can apparently use any existing GIF present on the forum or elsewhere...
There is no (reasonable) technical way to prevent this, save for disabling externally hosted avatars.
« Last Edit: September 25, 2023, 01:46:41 pm by magic »
The following users thanked this post: Psi
