Things like that really piss me off. Don't the losers who design those things have anything better to do with their time?
Anyway, speed is fine my end, cheers. Do you host the forum yourself, or is it an off-site service, Dave?
I run a site on some machines. I created an admin with a log file if someone tried to break in it. I checked the logs the other day.. 90 IP requests < 2minutes from 1 IP. A few weeks later it happened again, 10 more times.
So I looked up the access logs of Apache, and it turns out they crawl the server for directories like install/, admin/ , sqladmin/ phpmyadmin, etc (all those directories people typically put their site or database administration in). They hope to find out someone forget to put a password on their database admin (which happens more often than you think), or forget to remove the install or maintenance scripts for forums (so you can create a new root administrator or something).. Picked the first 10 directories of the list, created an auto IP ban script for it, problem solved. Over 400 IP's have been banned now
I believe all these attacks are automated. If they can figure out where a leak is , they can figure out how to write a script for it to automatically attack everything. That's why it's quite important to keep software updated. If there is a severe leak, hackers can just crawl every site, check the software versions and try to exploit it. And the bottom of the page tells the board software version, the HTTP headers the server software; nothing is hidden on the internet..
@Serverpark: Hmmm, nice machines. I wonder if it wouldn't be more efficient to use racks instead of full desktop PC enclosures. Ah well, that's the hosters problem
How much traffic does the eevblog.com use per month for the forum?
However, out here the forum still seem kinda slow..
