I had a computer where the 5v rail had a little oops, and applied the unregulated rail to the output. The overvoltage crowbar as well turned out to be faulty and non functional.
Look at DVM during testing and it shows 14.xx Volts. Check range, then quickly turn the power off.
Changed every part in the 5V regulator aside from the capacitors. Transistors, diodes, voltage reference diode, resistors and the 2 power transistors on the big case warmer heatsink along with all 3 parts in the 5V crowbar that did not work. Turn it on and 5V rail is back, and within limits, but the fault is still there. Fault finding time, so simply change each card starting from the back to do a quick isolation ( having a bright orange unit marked Maintenance really helps here for known working stuff) and after 4 cards it works. Luckily a card that rarely fails, so plenty of spare ones to put in and close it up and test then send out to the waiting plane.
Later look at the old one to see why, and one flatpack is looking somewhat discoloured on top. PM5403 hex inverter with open collector outputs, ironically a 30V rated part on the outputs, had gotten really hot and melted it's lid off, and then went open circuit on all 6 sections. Funny enough this is used to implement the 5 second delay, and simply drives a relay. It has an enable that is wire or'd from the power supply and will only start timing if the supplies are all over 3V. 14V and it died, at well over the 7V abs max for TTL. The rest of the devices surived unharmed, including EPROMS and some NMOS DAC's.
