I wonder what appliance uses less energy with less voltage?
Quote from: tszaboo on October 19, 2024, 08:41:04 amI wonder what appliance uses less energy with less voltage?Incandescent light bulbs I guess?OK, in fairness, old gadgets with linear regulated power supplies would burn off more waste energy as heat with higher input voltages.
As mentioned above, a large proportion of loads will draw about the same total energy over a range of voltage, but at lower voltages, transmission losses will be higher, so I wonder if that would offset any gains from those appliances that draw less at lower voltages.
Quote from: tooki on October 19, 2024, 11:09:07 amQuote from: tszaboo on October 19, 2024, 08:41:04 amI wonder what appliance uses less energy with less voltage?Incandescent light bulbs I guess?OK, in fairness, old gadgets with linear regulated power supplies would burn off more waste energy as heat with higher input voltages.Any resistive stuff, such as space heater, kettle, toaster, clothes iron, hair drier.
Quote from: tooki on October 19, 2024, 11:09:07 amQuote from: tszaboo on October 19, 2024, 08:41:04 amI wonder what appliance uses less energy with less voltage?Incandescent light bulbs I guess?OK, in fairness, old gadgets with linear regulated power supplies would burn off more waste energy as heat with higher input voltages.I wonder what percentage of total electronic load on the grid is linear supplies in 2024?
I wonder how many MBAs working at the power company, giving interviews know the difference between power and energy.
^Out of things I mentioned it's applicable to clothes irons and electric kettles. Some space heaters depending on room temperature.
Quote from: mikeselectricstuff on October 19, 2024, 09:14:37 amAs mentioned above, a large proportion of loads will draw about the same total energy over a range of voltage, but at lower voltages, transmission losses will be higher, so I wonder if that would offset any gains from those appliances that draw less at lower voltages.Presumably this would be accomplished by changing taps on neighborhood or individual customer transformers whenever they do service, not lowering the voltages on long distance transmission lines. So the impact on transmission losses would be quite small either way. Constant power devices would see their net transmission losses go slightly up, while resistive loads with thermostats would have losses go down slightly due to spreading the load out over more time.
Quote from: wraper on October 19, 2024, 04:51:20 pm^Out of things I mentioned it's applicable to clothes irons and electric kettles. Some space heaters depending on room temperature.Clothes irons and electric kettles both have control loops, they heat until a threshold temp is hit. Lowering their on-state power draw won't appreciable change their total energy draw (and in the case of a kettle may increase it, because more time is spend wasting heat to the environment).
Quote from: ejeffrey on October 19, 2024, 04:34:10 pmQuote from: mikeselectricstuff on October 19, 2024, 09:14:37 amAs mentioned above, a large proportion of loads will draw about the same total energy over a range of voltage, but at lower voltages, transmission losses will be higher, so I wonder if that would offset any gains from those appliances that draw less at lower voltages.Presumably this would be accomplished by changing taps on neighborhood or individual customer transformers whenever they do service, not lowering the voltages on long distance transmission lines. So the impact on transmission losses would be quite small either way. Constant power devices would see their net transmission losses go slightly up, while resistive loads with thermostats would have losses go down slightly due to spreading the load out over more time.I'm talking about losses in the cabling from the transformer to the house - relatively short distance, but a lot of it - no idea of the avarage resistances involved.
Quote from: wraper on October 19, 2024, 04:38:08 pmQuote from: tooki on October 19, 2024, 11:09:07 amQuote from: tszaboo on October 19, 2024, 08:41:04 amI wonder what appliance uses less energy with less voltage?Incandescent light bulbs I guess?OK, in fairness, old gadgets with linear regulated power supplies would burn off more waste energy as heat with higher input voltages.Any resistive stuff, such as space heater, kettle, toaster, clothes iron, hair drier.Those will use less power, but the same energy because they need to run longer.
“If we drop the voltages back down to [the 230v standard], that creates an enormous amount of headroom” for more solar power exports, said Kuiper, who pressed for changes while at the Esb and since.
What a weird article. They blame the voltage, but actually it's the at capacity last mile LV network. Most older network I'm, sure in AU also were laid out with a lower "typical household" load then today.
Quote from: tooki on October 19, 2024, 05:48:36 pmQuote from: wraper on October 19, 2024, 04:38:08 pmQuote from: tooki on October 19, 2024, 11:09:07 amQuote from: tszaboo on October 19, 2024, 08:41:04 amI wonder what appliance uses less energy with less voltage?Incandescent light bulbs I guess?OK, in fairness, old gadgets with linear regulated power supplies would burn off more waste energy as heat with higher input voltages.Any resistive stuff, such as space heater, kettle, toaster, clothes iron, hair drier.Those will use less power, but the same energy because they need to run longer.Half of those are not even temperature controlled.
In US the nominal was changed over the years 100>>110>117.
