Author Topic: EEVBlog on your lab test gear  (Read 3680 times)
Offline APSTopic starter
« on: December 19, 2009, 01:09:11 am »
Dave, I saw test gear behind you and tried to figure what it is. It was like this: there is a power supply, I think there is a func. gen. or maybe it isn`t, there is some DIY equipment, what is that on the upper shalf etc.
I think it would be great to see EEVblog about test equipment in the lab where you recording EEVblog. The stuff you use every day, those you use every there and then.
It would be educational if you say someting about where its used and how to use it (especially for specialised equipment), some spec to look for etc. When did you first needed that item and all other stuff you think of.
Offline EEVblog
Re: EEVBlog on your lab test gear
« Reply #1 on: December 20, 2009, 01:03:57 am »
It's on the to-do list. Just need to clean up and probably get the wife to do some camera work...
Dave.
Offline embedded
« Reply #2 on: February 28, 2010, 07:16:16 pm »
Dave.
Dave
Also add a equipment list of what you have as text document with perhaps your personal rating.
By the way congrats on a fairly well organized bench.  I think I am looking at the back wall of your house perhaps start the blog walking to your workbench.  Borrow a cheap steady cam deal like the RC guys have (Weight on bottom consumer cam on top) for the walk.  You can try this with a monopod with held between your fingers and with a brick on the bottom.
Cheers
John VE3GYV
If it wasn't hard we would not be paid to do it.
VE3GYV, KF5AFJ
