Hey Dave
As it seems, wireless charging is suddenly all over the place. Generally a very convenient way to get rid of the hundreds of chargers, the cable salad and the anoying propriatry connectors. But what about the over all efficiency of such systems? As far as my understanding of physics and electronics goes, the efficiency of a transformer drastically reduces the bigger the gap between the two spools is, no matter what exotic waveform is used to transform the power. But see how TI tries to convince developers with their bogus calculations:
http://www.wirelesspowerconsortium.com/technology/why-not-a-wire-the-case-for-wireless-power.htmlEspecially compare slide 7 to 8. They claim that their system has a bigger over all efficiency than a wired charger assuming that their AC/DC "adapter" already has an 80% efficiency to begin with. They relativise to the end of the presentation but still assume a higher developed charging system in their next gen controller which should be more efficient than a regular charger. Smells like BS to me.
Of course, the topic is a bit more complex than that. Less copper used, maybe less different chargers (if the industry will agree upon a common standard which seldom happened in the past), more efficient if the primary side detects when no device is in range and shuts down, but more electronics for the transmission and the detection is needed.
Are we going a huge step back in terms of energy efficiency if we widely introduce this technology to humanity? Might be an interesting topic for a white board session. What do you think?
Cheers,
Andy
