my 8$ meter is still working. its good to 5% with a resistive load.
Ah yeah, those aren't bad as long as it's HRC fused + CAT II.
lol, you have to be a special kind of stupid to short out your 480v mains with a clamp meter.
I'm actually not scared because it happens on the "IT" type PC/computer-repair forums. This one is REALLY bad for that. Some people even have confessed to sticking screwdrivers into their power supplies, because the fan quit ( curse gaming runs this, which is probably one of the largest gaming networks available, over here people use dollar store meters to measure mains )...
http://www.mmo-champion.com/content/ ( fertile soil for EEVBLOG )
Note: They've very resistant to even using 80 plus standard PSUs. Most people prefer the $35 chinese passive-PFC models with glass fusing, terrible heatsinks, no isolation cutouts, poor ventilation, and also the trademark of a shit PSU: soldering all similar rails together and letting the inductors deal with it. Of course the crowbar diodes will be able to shut them down in an emergency, but eventually the fan dies, the caps leak, or you start to hear high pitched whining (it's usually the regulators and damage to the passives/reactives. Reminds me of those loud camera flash recharges back in the days of 35MM and other film) There are some good "channel well" PSUs, but everyone here thinks that when you buy the most expensive corsair brand model you can get, that it's not made by seasonic or FSP ( two biggest OEMs in the PC power supply market, which is surprisingly boring, and full of people who are impatient )...
( Who's Who In Power Supplies, 2013: Brands Vs. Manufacturers )
http://www.tomshardware.com/reviews/power-supply-oem-manufacturer,2913.htmlA lot of the low end ones APEVIA, and other brands make actually come from this model (APEX AL-A400ATX 400W). They're just repainted and claim it's been upgraded. Arc welding is a hidden feature you can sell:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817154013If you buy a corsair, thermaltake, ocz, or other model, it's usually got a notch on the PCB for each power rating ( 500, 550, 600, 650, 700 ). Not really important, but it at least shows the tooling is the same. So you can swap out the linear ICs, caps, the fan, or even the heatsink. Easily convert a $30 model into a $100 model for not too much. It is a time waster converting all the PCBs though. You can get better money out of just replacing the entire PCB. Most of the time they keep the tooling the same on all the boards, and use some strange U shaped metal prong with a heat shrink tubing over it, so they bridge the rails without having to worry about the wires they removed to gimp the PSU. Maybe that's not fair to say that, but this is an old OCZ model, before they went bankrupt, so I'm not mentioning something I've seen now ( probably still true today for most PC stuff. I'd much rather find a gimped seasonic with individual rails, and replace it how I see fit. I'm sure you could even just solder the entire thing to a separate PCB and split it inside the case to get the 80 plus gold performance, for awhile at least until you could afford to do your own runs. You could probably just relabel them and sell them to crazy people. Not that that's good, but it seems to be the norm these days... )
