Author Topic: Fuction Generators - What/Why & how much  (Read 3275 times)
Offline ikrelTopic starter
« on: November 07, 2011, 07:06:53 am »
I'm not sure this is even the place to post/request this, but I was wondering if Dave could do a video about function/waveform generators.I would like to see his opinion on why someone would need one, how to use it and maybe a recommendation or two on what to look for when attempting to buy one.
Offline McMonster
    • McMonster's blog
Re: Fuction Generators - What/Why & how much
« Reply #1 on: November 07, 2011, 08:18:06 am »
I second that, this is probably the only popular piece of gear that did not have much cover in the videos.
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: November 07, 2011, 09:20:15 am »
in Shahriar's Vidz of TheSignalPath, he showed how we can use...
1) Bench Power Supply.
2) Function Generator.
3) Oscilloscope
4) Spectrum Analyzer
in building a working circuit.
http://thesignalpath.com/blogs/2011/10/17/tutorial-on-linear-and-non-linear-circuits/#comments
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #3 on: November 10, 2011, 10:54:38 am »
Couldn't agree more with mecha, to do analog design, you need a test signal source and that's what an FG is.  FG is synonymous with signal generator, but the latter term is more associated with high frequency sines for RF work in the AM and FM bands, while FG was more versatile ... it generated more 'functions'.  Audio generators are similar except they tended to create very high purity sine waves for audio testing, and threw in sometimes square or triangle waves as side benefits.
http://en.wikipedia.org/wiki/Signal_generator
1-3 are the absolute minimum you need to do analog design work with #4 being a DMM.  Luckily a crude spectrum analyzer exists as a software based FFT analyzer in most #3 if you get a DSO instead of analog.
3) Oscilloscope
Best Wishes,
 Saturation
Offline Electronic
« Reply #4 on: December 08, 2011, 09:20:56 am »
I vote for this one.
More tests of function generators.Dave had one, and closed it with DDS are better but then no tests on a DDS.
I also would like to see tests on the powersupplies he has inte the amazon-shop and I can't see any function generators there.
