Author Topic: Geoclense Home Harmonizer  (Read 3763 times)
Offline MisterEdTopic starter
« on: December 13, 2016, 01:08:21 am »
Here is a quality, "Proudly Designed and Manufactured in Australian" product that I think will be awesome for a test of their claims or tear down if you haven't done it already.
https://www.facebook.com/FAILElectrical/posts/668823023294829
http://www.orgoneffectsaustralia.com/product/geoclense-home-harmonizer/
I love the international versions, looks like they just glued an adaptor plug on.
By inserting the Geoclense and measuring with the Lecher antenna, I can con?rm that it is possible to reach the following frequencies:-
The Five Harmonies: Rating and measuring higher life energy (In houses)
2,5 Hz : Cellular (Can find it everywhere)
8 Hz : Earth or Telluric Energy (Can find it only in 20% of the houses)
12 Hz : Cosmic or Heaven Energy (Can find it only in 10% of the houses)
15,3 Hz : Electromagnetic Synergy (Can find it only in churches)
17,6 Hz : Global Synergy (Can find it only in churches or cathedrals)
With the Geoclense: 2,5 - 8 - 12 - 15,3  17.6Hz = 100% ...which equates to healthy, positive energy free of EMF, RF and geopathic stress interference.
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Geoclense Home Harmonizer
« Reply #1 on: January 03, 2017, 09:54:19 pm »
This is the most OTT bullshit outfit I've ever seen - surely there's enough of an obvious con there to get local trading standard to shut them down?
Day Job: Mostly LEDs
Offline Brumby
« Reply #2 on: January 04, 2017, 01:13:34 am »
You would think so....
I do like the way they dress up this turd with various frequencies for various "energies".  I'd do a facepalm - except it's not worth the energy.
(Facepalm energy runs at 50Hz in Australia - or so I believe)
Offline grifftech
    • youtube channel
« Reply #3 on: May 04, 2017, 08:14:21 pm »
It runs at 59.9Hz in Texas
Offline thm_w
  • Non-expert
« Reply #4 on: May 04, 2017, 08:37:31 pm »
At first I thought it was actually generating negative ions: "The Geoclense is a negative charge resonance field generator designed to balance positive charge resonance"
But then they say this, "Note: The Geoclense does not consume any electrical supply."   :wtf:
