Author Topic: Important Topics Mod  (Read 9419 times)
Offline EEVblogTopic starter
« on: February 22, 2017, 10:20:42 pm »
I've added a mod that allows you mark topics as important.
There is a button down the bottom to toggle.
And you should have a new menu item (mine is under the Home button, but could be under Moderate) titles "Out Important Topics".
The following users thanked this post: MarvinTheMartian
Offline MarvinTheMartian
Re: Important Topics Mod
« Reply #1 on: February 22, 2017, 10:42:14 pm »
It should read "Our Important Topics"  ;D
Mine is also under the Home button.
So, because you say 'Our' does this mean it is global for all users, or is it for individual use for their own important items?  :-//
Reviving my old hobby after retiring! Know so little...only one thing to do...watch Dave's videos and keep reading the forum! ;-)
Offline bitseeker
« Reply #2 on: February 22, 2017, 10:45:56 pm »
It appears to be global since this topic, marked important, appears in the "Our important topics" list. I was able to unmark and remark it as important.
« Reply #3 on: February 22, 2017, 10:47:20 pm »
Yes, that is what I am assuming at this stage too.
Offline tautech
« Reply #4 on: February 22, 2017, 10:49:58 pm »
Yeah, how do you actually use this feature ?
Got some old tabs open but I can't see any changes or methods of adding importance.  :-//
Is this equivalent to "Watching" a thread ?
Edit
Got no important's now, so how do I add one ?
« Last Edit: February 22, 2017, 10:51:57 pm by tautech »
Offline AlfBaz
« Reply #5 on: February 22, 2017, 10:58:19 pm »
Edit
Yeah somebody must of "unmark as important" to test as it was there and then it disappeared.
Couldn't find it either until I scrolled all the way down. It's underneath the share box, next to "link to calendar"
Offline AlfBaz
« Reply #6 on: February 22, 2017, 11:06:15 pm »
I just marked it important, the button down the bottom changes its text to unmark, which I did and then is disappeared again.
Wondering what the use case for this is if anybody can mark, unmark a topics importance
Offline RGB255_0_0
« Reply #7 on: February 22, 2017, 11:21:28 pm »
And I just marked it unimportant.
Not sure how useful this feature really is - seems more useful for moderators that don't feel it's important enough to pin?
Your toaster just set fire to an African child over TCP.
« Reply #8 on: February 22, 2017, 11:30:38 pm »
I agree, what is important to one person may not be so to another. Who would be the judge as to the importance of a particular topic?  :-//  Should it be the moderators only who can unmark?
It could also be an avenue for unwanted abuse (someone unmarking a topic every time it was marked by an particular individual) :--
« Reply #9 on: February 22, 2017, 11:31:14 pm »
The idea is that you can set up a list of threads that are important to you, or so you don't forget etc, so you can easily find and access them again.
« Reply #10 on: February 22, 2017, 11:32:19 pm »
Oh, hang on, is everyone saying that the list is NOT different for each individual?
« Reply #11 on: February 22, 2017, 11:35:16 pm »
Exactly! It seems to be global Dave!  :-//
« Reply #12 on: February 22, 2017, 11:36:18 pm »
That would be excellent if you can get it to work on an individual basis rather than global.  :-+
Offline tautech
« Reply #13 on: February 22, 2017, 11:37:28 pm »
Yep, I've been crashing around in Profile trying to find a way to turn this feature on.....no luck, maybe it only works for you.  :-//
Global setting ?
Offline AlfBaz
« Reply #14 on: February 22, 2017, 11:51:18 pm »
Hi tautech
Here are some pictures of where these things are
Offline tautech
« Reply #15 on: February 22, 2017, 11:56:05 pm »
Hi tautech
Mint.  :-+  :-+  :-+
Yep, older tabs I have open don't display it.
Refresh them and then the Mark as Important button is available to add to Important and then visible in the drop down under Home.
Long overdue addition, thanks Dave.  :)
« Last Edit: February 23, 2017, 12:00:09 am by tautech »
« Reply #16 on: February 22, 2017, 11:59:15 pm »
Ok, bugger, I'll remove it then, it's of no use.
Offline tautech
« Reply #17 on: February 23, 2017, 12:01:39 am »
Please don't.....some blind old fart couldn't see it.......It works fine.
Offline bitseeker
« Reply #18 on: February 23, 2017, 12:06:22 am »
He's removing it because it's a global setting. You don't get your own list of important threads. If it was a per-user list, that would be useful.
Offline tautech
« Reply #19 on: February 23, 2017, 12:29:02 am »
Why not, other forums have a "Watch Thread", isn't this the same ?  :-//
Offline bitseeker
« Reply #20 on: February 23, 2017, 03:40:51 am »
I'm not familiar with those other forums, but with the feature on this forum, if you marked a thread as important, anyone else could remove it from the list or add some other thread to the list. You would have no control over what's in it. It would be a free-for-all.
I don't know why it was written that way. Maybe it was only intended for moderators to use or something. In its current form, it's not useful. If it was a personal list, it would be nice.
« Last Edit: February 23, 2017, 03:42:36 am by bitseeker »
« Reply #21 on: February 23, 2017, 03:52:03 am »
I think it would be very useful if it was able to be personalised. :-+
Perhaps there is a setting to change it from global to individual that Dave has yet to discover.  :-//
