Author Topic: LCD panel meters, but more than one at the same time  (Read 1787 times)
Offline efronTopic starter
« on: February 28, 2014, 06:04:15 pm »
Hello,
A digital panel meter is very easy to use when used as standalone.
But when one wants to use more than one at the same time, let's say two (e.g. one for voltage measurement, the other for current measurement) things can become difficult beause of things to take care of depending on the meter configuration; common-ground or isolated power supply.
All this 'hidden' stuff is not easy to find in the internet. Well, this is my case, I still don't know how to manage safely two panel meters powered in parallel by the same isolated power supply without blowing them out!
Well, to fix the problem I could use 2 isolated power supplies, but well, even in the hobbyst world we can do better than that.
Thanks,
Efron
« Last Edit: February 28, 2014, 07:27:42 pm by efron »
Offline Neverther
Re: LCD panel meters, but more than one at the same time
« Reply #2 on: March 03, 2014, 08:53:40 pm »
This seemed familiar.
https://www.eevblog.com/forum/projects/stuck-when-using-2-lcd-panel-meters-in-parallel
Yeap, it was mine.
But I can't still find what is hidden inside common-ground and non common-ground digital panel meters.
