Author Topic: Metal Core PCB's  (Read 1530 times)
Offline SnoopyBlueTopic starter
Metal Core PCB's
« on: February 28, 2014, 09:45:53 am »
Came about Aluminium Core PCB. Interesting thing, but don't know much about it. Basically they are used for and came about with power LED's, I guess because of heat dissipation. But I guess they are/can be used with other power circuits ... amplifiers, LDO's, etc. Has anybody experience with it? I guess they are single sided, but is there possibility of multi-layer? How are connection's done with other boards? Anyone had hands-on experience with them?
Best Regards,
Offline Corporate666
  • Remember, you are unique, just like everybody else
Re: Metal Core PCB's
« Reply #1 on: February 28, 2014, 11:53:44 am »
Best Regards,
I've used lots of metal core PCB's (MCPCB).  Honestly, they aren't really any different than FR-4.  I have done plenty of 2-sided MCPCB's, but of course it adds to the cost.  I haven't used multi-layer but I believe they exist... although probably much more cost efficient to put the necessary heat-sinked parts on the MCPCB and use an interconnect to a more complex board when necessary.
As for connections - no different than any other PCB.
It's not always the most popular person who gets the job done.
Offline poorchava
  • Troll Cave Electronics!
« Reply #2 on: February 28, 2014, 01:27:55 pm »
Multi-layer boards exist, but they usually use micro-via process rather than normal drilled vias. They are expensive (with capital 'E'), even in high volume. Soldering that stuff with normal iron and without a preheater is very hard.
