Author Topic: Planned Downtime @ 2018-04-21 00:00:00 GMT.  (Read 19677 times)
Offline gnifTopic starter
« on: April 19, 2018, 10:34:08 pm »
I will be moving the forums and website over to the new cluster at 2018-04-21 00:00:00 GMT.
Unfortunately due to the huge jump software versions this can not be done without causing some downtime.
The forums should not be down for any longer then an hour provided everything goes OK.
If it does take longer please be patient as we will be working to restore operations as fast as possible.
Part of this migration includes upgrading fully to InnoDB tables on the Barracuda engine, as well as moving to utf8mb4 collation.
Leading up to the move I will not be able to answer questions as I will be preparing so that everything goes smoothly.
« Last Edit: April 23, 2018, 08:46:07 am by gnif »
The following users thanked this post: EEVblog, SeanB, madires, 3roomlab, dr.diesel, ovnr, tautech, DIPLover, ez24, TheSteve, Fire Doger, frozenfrogz
Re: Planned Downtime @ 2018-04-21 00:00:00 GMT.
« Reply #1 on: April 20, 2018, 04:37:48 am »
Forums are now working again, other areas of the site are still to be completed.
Please hold off reporting any issues until then.
The following users thanked this post: EEVblog, hendorog, ChunkyPastaSauce, frozenfrogz
Offline Monkeh
« Reply #2 on: April 20, 2018, 04:44:52 am »
Glorious Ω, how I have missed thee.
Three cheers for gnif!
Offline trevatxtal
« Reply #3 on: April 20, 2018, 04:52:13 am »
Sadly I am still in Friday 20 April While you are in Sat 21 already.
Is it possible for the time adjustment box to be used .
Thank you
Trevor.
M0XOL
Offline Monkeh
« Reply #4 on: April 20, 2018, 04:55:25 am »
I wasn't going to mention the minor 24-hour mistake.
The following users thanked this post: nugglix
Offline EEVblog
« Reply #5 on: April 20, 2018, 05:02:16 am »
Does this mean that the UTF8 support people have been complaining about for a long time is now solved?
Offline EEVblog
« Reply #6 on: April 20, 2018, 05:04:48 am »
Thanks gnif, this has been a huge amount of effort on your end  :-+
I encourage everyone who uses the forum to support gnif's efforts on Patreon if able.
https://www.patreon.com/gnif
Offline hendorog
« Reply #7 on: April 20, 2018, 05:43:43 am »
Not sure if I'm suffering from bias but the site seems quite a bit faster to me. :clap:
Offline Ampera
    • Ampera's Forums
« Reply #8 on: April 20, 2018, 05:53:13 am »
Уелл, даве, иф тхис мессаге ис аппеаринг он тхе форумс, тхен И ам гуессинг тхат уи хаве Уникоде суппорт.
I forget who I am sometimes, but then I remember that it's probably not worth remembering.
EEVBlog IRC Admin - Join us on irc.austnet.org #eevblog
« Reply #9 on: April 20, 2018, 06:13:35 am »
It should be quite a bit faster again now, the reverse proxy via the old server was just removed.
« Reply #10 on: April 20, 2018, 06:14:49 am »
Not done yet, but you're most welcome.
It should be, the following seems to indicate so :)
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #11 on: April 20, 2018, 07:07:38 am »
Gøød news everyΩne!
Thanks a million!
He’s like a trained ape. Without the training.
« Reply #12 on: April 20, 2018, 07:54:56 am »
Seems database fail over isn't working yet... there may be several short outages while I correct this.
Offline EEVblog
« Reply #13 on: April 20, 2018, 08:21:06 am »
The initial page load is MUCH faster than before  :-+
And I wasn't complaining about the speed of the old server
Offline tautech
« Reply #14 on: April 20, 2018, 08:52:18 am »
Had to shoot and run just when gnif pulled the server down and not long been back.
First impressions it is a wee bit faster now.
Thanks Dave and gnif for bravely taking this step forward.  :clap:
Avid Rabid Hobbyist
« Reply #15 on: April 20, 2018, 09:14:43 am »
Database failover now working, but something wrong with recovery, investigating.
« Reply #16 on: April 20, 2018, 09:24:31 am »
failover and recovery of the database between servers is now perfect :D
Offline nctnico
« Reply #17 on: April 20, 2018, 09:37:51 am »
Are the PDF attachements also fixed?
« Reply #18 on: April 20, 2018, 10:02:10 am »
First I have heard of it... whats the problem?
Offline Brumby
« Reply #19 on: April 20, 2018, 10:56:07 am »
I don't know that it's a "problem" as such - just a size limitation.
Offline BravoV
  • +++ ATH1
« Reply #20 on: April 20, 2018, 11:15:46 am »
At random, still getting "500 Internal Server Error nginx/1.10.3" message, and a refresh cleared it out. Still fast though.
Offline BravoV
  • +++ ATH1
« Reply #21 on: April 20, 2018, 11:25:30 am »
It happened again just few seconds ago, just trace back this post's time and my IP, hope this helps.
Offline Monkeh
« Reply #22 on: April 20, 2018, 11:45:13 am »
It is indeed, we can now use such advanced symbols as Ω rather than trying to use something ugly like  \$\Omega\$,
Offline gamalot
  • Correct my English
    • Youtube
« Reply #23 on: April 20, 2018, 11:56:35 am »
Chinese? 中文  :-+
« Reply #24 on: April 20, 2018, 12:06:18 pm »
Expected, I am still performing server tuning. Unfortunately all the prep work int the world doesn't prepare you for real world workloads.
