Author Topic: Podcast Problem  (Read 4059 times)
Offline EEVblogTopic starter
Podcast Problem
« on: May 19, 2010, 01:13:07 pm »
Sorry everyone, there appears to be a major problem with the Podcast feed and I have no idea why. My usual delete post and try again method is no longer working.
Likely something wrong with PodPress my Wordpress plugin that handles the iTunes/podcast stuff for me.
I'm working on it, but I ain't no Linux Penguin...
Dave.
Re: Podcast Problem
« Reply #1 on: May 19, 2010, 01:33:18 pm »
Ok, looks like I may have coaxed it into working.
The XML feed has the correct file attachment names instead of the corrupt strings it had before:
http://feeds.feedburner.com/ElectronicsEngineeringVideoBlog?format=xml
Everything feeds off this, so I believe it should get fixed in iTunes as well, can someone confirm?
Dave.
Offline tsa
Re: Podcast Problem
« Reply #2 on: May 19, 2010, 01:51:54 pm »
Dave,
iTunes shows all episodes right now (up to ep. #88, even episode 87, which was published a week ago on YouTube), downloads and plays perfectly!
Thank you for your enthusiastic work!
Thomas
« Last Edit: May 19, 2010, 02:08:29 pm by tsa »
Offline TheDirty
Re: Podcast Problem
« Reply #3 on: June 04, 2010, 03:38:51 pm »
The RSS feed still doesn't work.  Nothing since #86.
Mark Higgins
Re: Podcast Problem
« Reply #4 on: June 05, 2010, 12:03:35 am »
The RRS feed works for me. I have it on my iGoogle home page and they all show up just fine.
Anyone else?
Shows up just fine on the feed page:
http://feeds2.feedburner.com/ElectronicsEngineeringVideoBlog
Dave.
Offline charliex
  • Car Hacker
Re: Podcast Problem
« Reply #5 on: June 05, 2010, 12:14:41 am »
works for me
EEVblog - Electronics Engineering Video Blog PodcastRestore | ShareDeleteEdit
Loading...
EEVblog #91 – $50 Multimeter Shootout – Extech EX330, Amprobe AM220, Elenco, Vichy VC99, GS Pro-50
Product Design FAIL – IDEAL Multimeter
Telstra got the kick up the arse they deserved!
Offline dengorius
Re: Podcast Problem
« Reply #6 on: June 05, 2010, 01:39:47 am »
Yep, same here. Up and running
Offline TheDirty
Re: Podcast Problem
« Reply #7 on: June 05, 2010, 01:48:06 am »
This is the feed that I was using, which is now dead.  I'll move to the feedburner one, but you might want to forward this URL if others are using it.
http://www.eevblog.com/?feed=podcast
Mark Higgins
