Author Topic: Problem With Forum Search  (Read 8373 times)
Offline EEVblogTopic starter
« on: August 19, 2017, 02:46:16 am »
Take this topic as an example:
https://www.eevblog.com/forum/repair/ntc-help-needed-for-fluke-pm3082/
With the title: "NTC help needed for Fluke PM3082"
Search for "PM3082" in various ways and the thread doesn't show up at all.
Has anyone had similar issues recently?
I know that SMF search has always been a bit troublesome, but I just want to make sure it's not a recent thing like new threads are not getting indexed or something
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
Re: Problem With Forum Search
« Reply #1 on: August 19, 2017, 02:52:01 am »
there is a recent thread where folks were discussing this.
https://www.eevblog.com/forum/chat/eevblog-search-engine-missing-threads/
Offline IanB
« Reply #2 on: August 19, 2017, 03:38:06 am »
I have to say that I never use the forum search on any forums. I never think it works very well.
For the query given, I would type the following into Google:
site:eevblog.com/forum pm3082
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #3 on: March 16, 2018, 10:43:21 pm »
I quite often use the forums search feature and have always found it rather lacking but I now suspect that something has changed of late to make it almost entirely unusable. As can be seen from the images below the first page is where I entered the search term and then on the second page the returned and expected results, the third image shows what is returned after I select page 2 or next as it then displays an "Adjust Search Parameters" page and the prior search results disappear altogether.
One thing I have noticed is that the returned search results are now displayed in reverse chronological order whereas previously I remember them as being all over the place, I think this is an improvement. I have tested the search feature on two different devices with the same result but somebody else may want to verify my findings, or the lack of.
Offline klaus11
« Reply #4 on: April 20, 2018, 08:15:05 am »
Error,function Search the topics appear but when clicking on them the links do not work.
Server Error 500...
HP3458A, HP3245a, Keithley 2000, Fluke 87V, Rigol DP832, TEK TDS5052B, HP33120A
Offline gnif
« Reply #5 on: April 20, 2018, 08:56:08 am »
Server Error 500...
We just moved servers, there are some things to sort out still. But even still I can not reproduce the problem, what were your search terms?
Offline klaus11
« Reply #6 on: April 20, 2018, 06:48:48 pm »
Server Error 500...
DPO7104
Offline metrologist
« Reply #7 on: April 20, 2018, 07:20:44 pm »
I searched "DPO7104" and got one result, this thread. I clicked it, and here I am...
Offline gnif
« Reply #8 on: April 20, 2018, 09:52:05 pm »
Works fine for me too, I can not replicate the fault.
I did note however the top right search box is using the old search instead of sphinx, I will fix this today.
Offline klaus11
« Reply #9 on: April 21, 2018, 03:59:08 am »
If it works now there is no error.
8 results appear  :-+
Offline metrologist
« Reply #10 on: April 21, 2018, 01:40:57 pm »
I guess the forum search only searches in the subforum you are looking at. I get 8 results from home page.
Google gives me 6 results: DPO7104 site https://www.eevblog.com/forum/
Offline StillTrying
  • Country: Broken Britain
« Reply #11 on: April 28, 2018, 03:44:21 pm »
Searching for the words    working on    gave a strange subject: html effect for me, haven't tried a different browser/PC yet.
Beginners / Custom Arduino PCB - not ong class="highlight">workingong> after assembly?
Offline gnif
« Reply #12 on: April 28, 2018, 04:25:19 pm »
What part of the forum were you on when you searched, I can't find the same result using the terms you provided.
Offline StillTrying
« Reply #13 on: April 28, 2018, 05:14:42 pm »
"What part of the forum were you on when you searched"
The search page LOL, the search in the menu on the left, not the top right search box.
It's hardly a major problem.
Edit: Well I'm glad he found it, and it wasn't just me!
« Last Edit: April 29, 2018, 06:20:16 pm by StillTrying »
Offline gnif
« Reply #14 on: April 29, 2018, 05:08:53 am »
I managed to replicate it, and I can confirm it is a bug in SMF.
The search is doing a string replace for words to highlight, you used the terms "working on". The highlight HTML is "<strong>xxx</strong>", but "strong" contains "on". SMF is erroneously replacing the text in it's own tag, generating the output:
<str<strong>on</strong>g>working</str<strong>on</strong>g>
One day developers might learn that "preg_replace" on HTML content is a very bad idea, there is no excuse anymore with PHP's DOMDocument class. Or even simpler, split the content into words (explode) and apply the highlight to the words individually, then join it back together (implode), rather then a mass search/replace.
« Last Edit: April 29, 2018, 05:15:14 am by gnif »
The following users thanked this post: EEVblog, StillTrying
Offline timelessbeing
« Reply #15 on: June 05, 2018, 07:57:50 pm »
I noticed another weird thing about the search. (At least, it's not the behaviour that I would expect.) The search results are in crazy order. It shows hits from 2017 before ones posted yesterday.
Offline Mr. Scram
  • Display aficionado
« Reply #16 on: June 05, 2018, 08:00:16 pm »
Newer threads aren't necessarily more useful.
« Reply #17 on: June 05, 2018, 08:27:42 pm »
... so are you going to tell us what is?
Offline Mr. Scram
« Reply #18 on: June 05, 2018, 08:41:26 pm »
Please leave your grating attitude in the other thread. Nobody is interested in us rubbing egos, no matter how sensual that may sound.
Newer threads may be small threads that died quickly, while older threads may have gone on for much longer and contain more valuable information. Relevance can be a metric, number of responses, number of responding forum members. There's more ways to skin the cat of presenting relevant search results.
« Reply #19 on: June 05, 2018, 09:00:06 pm »
My attitude is that you are a very annoying person, and it's really weird that you're following me around. You are now blocked so go rub someone else. Scram, Mr. Scam.
The many many forums I've visited all sort search results by date. I think it's what people expect.
The following users thanked this post: Mr. Scram
Offline metrologist
« Reply #20 on: June 05, 2018, 09:24:07 pm »
We have the capability to create look-up tables with relative term rankings to score a search result. It's more better...but it is even better to be able to select a sort order too, if that is desired.
« Reply #21 on: June 05, 2018, 10:07:37 pm »
Sorry false alarm. In advanced search, you CAN set the sort order of the results.
What about this: The search also seems to return only the most recent hit in a topic.
Example (this 5-page topic): https://www.eevblog.com/forum/projects/suggestions-for-high-resolution-tiltmeter-(inclinometer)-sensor/
Search for the forum for keyword "talyvel". You will see one result from the last page, but the word is mentioned 13 times going back to page 1.
This I think is a problem, especially on those 100 page topics.
« Last Edit: June 05, 2018, 10:15:55 pm by timelessbeing »
Offline metrologist
« Reply #22 on: June 06, 2018, 01:41:48 pm »
It looks like advanced search is just returning topics, not every message result within a topic. That might be desirable, but I think I recall seeing some search functions have a toggle to show topics or posts. The upper right search box returns all the results from within that topic, and it just returns the topics when searching from the forum index. :-//
« Reply #23 on: June 06, 2018, 07:07:17 pm »
The results takes you to the newest message. If you select "Show results as messages" in the advanced search, the results will also show the contents of the post.
That's good to know. At least I can pick a search depending on what I want.
« Last Edit: June 06, 2018, 07:09:55 pm by timelessbeing »
