Author Topic: teardown of an ultra compact high efficiency switched-mode power supply  (Read 3104 times)
Offline jonovidTopic starter
    • JONOVID
compare two switched power supply's from laptop pc's  with the same wattage.
one design is 10 or 15 years old, and the other is one of them next generation 2019 -2020 ultra compact high efficiency switched-mode power supply with an airtight case.  that are sold with laptop pc's
next generation switched power supply's come in an airtight case half the size of older designs.
what has changed in switched mode power design.
Hobbyist with a basic knowledge of electronics
Offline thm_w
  • Non-expert
Re: teardown of an ultra compact high efficiency switched-mode power supply
« Reply #1 on: December 16, 2020, 10:18:56 pm »
There are some cheap GaN units available: https://www.aliexpress.com/item/4001026960817.html
I don't know if current laptops are using that yet.
    • JONOVID
« Reply #2 on: December 17, 2020, 06:52:28 am »
purchased a HP laptop with a ultra compact 45watt 19vlot 2.5 amp battery charger that is half the size of older laptop charger designs.
the case is 90mm L (25mm is lost with a IEC C5 recessed 3 pin socket in the end)  25mm H   25mm W
this unit has no ventilation slots. in an airtight case.  it works fine,  ;D  but I do wonder about how its designed.  :-//
to stay cool .  as my 3 amp bench power supply needs lots of ventiltion.   can Dave do a teardown to unlock its secret?
« Last Edit: December 17, 2020, 06:59:56 am by jonovid »
Offline CJay
« Reply #3 on: December 17, 2020, 12:09:28 pm »
All theones I've got here are 25x35x90mm, be interesting to see if the new stock I'm meanto to be getting early Jan come with smaller ones.
I've got a couple of the 45W adapters which are dead enough (frayed or damaged cables which get failed by our H&S electrical safety checks) to be candidates for a teardown if he's interested.
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #4 on: December 17, 2020, 12:29:07 pm »
Seriously doubt there is any GaN in that thing. Pic or didn't happen!
Offline Weston
« Reply #5 on: December 17, 2020, 07:41:14 pm »
Back when Anker came out with a GaN based USB charger I bought one and took it apart, I was actually pretty underwhelming. It used a highly integrated power IC that has all the power FETs, control circuity, and isolators. I suspect that most modern chargers are something similar.
The one I took apart used a chip from Power Integrations, the primary side switch is GaN and it runs as a quasi-resonant flyback converter https://ac-dc.power.com/products/innoswitch-family/ . I think some might also use an active clamped flyback design, that topology is popular now.
Given the high level of integration they are pretty simple inside and I suspect that the GaN version of the power IC only costs a bit more than the Si version.
Offline sandalcandal
  • MOAR POWA!
« Reply #6 on: December 18, 2020, 03:34:39 am »
I recently saw a webinar from a reverse engineering firm that did a  brief segment on GaN-on-Si AC adapters. https://techinsights.wistia.com/medias/7ma357gv90 @16:50 to 21:20 Also https://www.techinsights.com/blog/navitas-found-inside-ravpower-rp-pc104-w-gallium-nitride-45-w-usb-c-power-delivery-charger and https://www.eetimes.com/ac-adapters-gan-sic-or-si/ (from the same author) They looked at a few including RAV Power, Made in Mind Mu One and mentioned Anker and FINsix. The implementations appear to be just based on reference designs of GaN ICs from Navitas and Popwer Integrations (which @Weston has also mentioned).
« Last Edit: December 18, 2020, 03:41:06 am by sandalcandal »
Disclosure: Involved in electric vehicle and energy storage system technologies
    • JONOVID
« Reply #7 on: December 19, 2020, 10:56:42 pm »
finally found a clue to what semiconductor technology is been used here!  :clap:
it is gallium nitride.
would a side by side comparison of the two types of technology be of any interest
IMO the implications are huge , less heat , less weight more compact electronics.
particularly in EV's or anything portable & high power.
« Last Edit: December 19, 2020, 11:17:36 pm by jonovid »
  • MOAR POWA!
« Reply #8 on: December 20, 2020, 06:05:41 am »
GaN is starting to see use in some EV applications
Tendency seems more towards SiC rather than GaN for EV applications however due to limited "high voltage" (>600V) performance of GaN. The newer >800V EVs seem to be thanks to maturation of SiC technology.
The following users thanked this post: thm_w, jonovid
