Author Topic: Testing an ADC and/or DAC  (Read 2162 times)
Offline JonnyBoatsTopic starter
    • BitsConnect
« on: November 20, 2011, 05:22:19 am »
Analog Devices publishes a nice whitepaper (http://www.analog.com/static/imported-files/tutorials/MT-010.pdf ) discussing the various types of errors and specifications for ADCs and DACs.
How would one go about verifying that a particular part one is considering using meets the requirements of the intended application?
For example suppose it is critical that the output of an ADC be monotonic for the circuit to work properly, how would one setup a test jig to verify that a particular part did in fact produce monotonic output?
The real idea here is not ADCs and DACs in particular but rather understanding how one goes about setting up test jigs for parameters that are not easily measured by standard bench instruments.
A simpler example might be graphing the temperature coefficient of a ceramic capacitor (http://www.niccomp.com/Products/TC_Ceramics.pdf ) .
Offline amspire
Re: Testing an ADC and/or DAC
« Reply #1 on: November 20, 2011, 05:49:10 am »
For an ADC, you apply positive sloping ramp on the input, and test to make sure all readings are equal or greater then the preceding reading.
For a DAC, you step through each incrementing voltage starting at 0 - say one step per millisecond. Put a differentiator on the output such as a 1nF capacitor from the output to the - input of an opamp with a 2.2 M feedback resistor. If the DAC is not monotonic at any point, there will be a positive spike on the opamp output.
