Author Topic: uCurrent Delivery Problems  (Read 4042 times)
Offline EEVblog
« on: November 26, 2018, 11:22:38 pm »
I know many people have placed back orders with Welectron, and are waiting for my store to carry it again too.
Sorry about the delays, here is the reason why.
I had the usual delays with parts supply, and the assemblers pipeline, it was hard to get a confirmed date.
Then I heard they were on the assembly line now and all was good so I should have had them last week.
A couple of days went by waiting for delivery and when that didn't happen I contact the assembler. Turns out they were getting bad yield on the test jigs, a lot of units were failing. They tried to troubleshoot themselves but finally gave up and asked me for help. They sent the test jigs back and they tested fine.
Upon closer inspection of the boards the 0.05% 2K2 resistor looked suspect, and sure enough measured out of tolerance (slightly, but you pay 40 cents a pop on these for a reason!)
And it physically looks different to the other precision resistor, like it's a standard high tolerance part instead of precision.
A photo of the reel (from Digikey) looks like the right part so I'm waiting to get that reel back to inspect and measure them.
Have also ordered another reel of a different brand.
So hope to get this issue confirmed and sorted shortly, but it will take some extra time.
This wouldn't be the first time I've had resistor tolerance problems from Digikey if it turns out to that.
« Last Edit: November 26, 2018, 11:26:08 pm by EEVblog »
Online MrMobodies
Re: uCurrent Delivery Problems
« Reply #1 on: November 27, 2018, 12:13:49 am »
Last time there was oscillation from the on Semi 321B/ LMV32B1AS5X part.
The following users thanked this post: Moriambar
Offline voltlog
    • VoltLog
« Reply #2 on: November 27, 2018, 08:52:17 am »
Looks like Dave and Murphy are good friends.  :-+
Offline Brumby
« Reply #3 on: November 27, 2018, 01:30:14 pm »
Murphy is a good friend to a lot of us here - but Dave's more prominent profile means he'll get the lion's share.
Offline LapTop006
« Reply #4 on: November 27, 2018, 01:58:58 pm »
Or just that he's actually needing parts to be in tolerance, wheras for many parts the only difference between 10k and 1M resistors may be a slight change in power usage.
Plus, unlike those of us building a few at hobby scale, he's doing a hundred or more a run, so a bad part we might notice and redo after testing then forget is more memorable.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #5 on: November 29, 2018, 12:24:38 pm »
I and a colleague have been sent wrong zeners. At work it made a right mess of things as zeners that were supposed to be for protection in a resistor divider network were conducting, on the second run with correct parts we found false positives in the diagnostics the zeners were part of. These assholes that call themselves distributors will happily send you a certificate of conformity or charge you for one but will they pay up when they pick the wrong parts?
Offline Moriambar
« Reply #6 on: December 11, 2018, 06:34:27 pm »
Welectron contacted me and they seem to be back in stock
Offline Simon
  • Global Moderator
« Reply #7 on: December 11, 2018, 06:47:54 pm »
No they show on back order.
Offline Moriambar
« Reply #8 on: December 11, 2018, 06:53:20 pm »
well they sent me an email telling me that they have new batches and that my order (placed at the end of october) has been shipped…
Offline Simon
  • Global Moderator
« Reply #9 on: December 11, 2018, 06:55:17 pm »
Ah, they have stock to cover back orders, maybe they don't have stock for more orders.
Offline Moriambar
« Reply #10 on: December 11, 2018, 07:02:26 pm »
Probably, but this means that new stock has started coming… right?
Offline Simon
  • Global Moderator
« Reply #11 on: December 12, 2018, 07:40:02 am »
Hopefully, I have no wind of stock myself.
Offline orbitrod
« Reply #12 on: January 03, 2019, 06:50:06 pm »
Does anyone know if the uCurrent GOLD Multimeter Adapters are back in stock?
Offline Simon
  • Global Moderator
« Reply #13 on: January 03, 2019, 06:54:10 pm »
I believe they are starting to come but back orders from the german reseller are being fulfilled before any will be available to purchase. I don't know where you prefer to buy from but i can notify you ass soon as I know they are on their way. I only sell what I have in my hand!
