I wonder what is worse.
When you ignore a thread (using the quick tools in New replies to your posts / unread posts since last visit), you no longer see it in any listings.
When you add a member to your Ignore list (Profile > Summary, Modify Profile > Buddies/Ignore list... > Edit Ignore list), you'll only hide the text of their post, but will still see the username everywhere.
Simply put, a strife/aggravation-causing username cannot be completely hidden, whereas an annoying thread can even if you replied to it yourself.
Therefore, the strife/aggravation-causing username is definitely worse, because you cannot avoid seeing it in the threads and thread lists.
that looks more like a personal problem, not a general problem.
No, it was a simple logical response to the question of "which is worse". I intended the response to show the underlying reason why an occasional thread that is against the rules is allowed by Dave to remain, whereas usernames are treated more strictly and with much less tolerance.
This forum is not a democracy; it is a benevolent dictatorship where whatever Dave says, goes. Even pointing out to the rules and saying that "but the rules say" is irrelevant, because the rules do not apply to Dave; they're just the best approximation of his intent for this forum.
Why tolerate a dictatorship? Because it is a
benevolent one. Dave has a very long track record showing he has zero interest in exploiting anyone, and very keen interest in interacting with many people in a mutually beneficial way. He's not perfect, but the intent is there; and without him, it is extremely unlikely this forum would exist. By participating here, we acknowledge that in this small corner of the Intertubes, we choose to abide by Dave's rules. If we don't like them, we can simply leave, and no hard feelings: this is not the only forum on electronics, after all. I like this nook, because he is very logical and rational compared to the average, but still uses
common sense and deals with each situation on an individual basis, instead of relying on rote reading of some rigid ideological or political rules.
Why didn’t you [benj38], silently, just report it to a moderator instead of making a topic of it?
Good question. I often report stuff I think is spam myself. My social skills are deficient in a funny way that makes me miss some details and see some other details others miss, so I often suspect any misunderstanding is on my end, and just ignore that stuff if I can.
Plus, not all seeming insults are insults. Labeling someone a
felon is, but for example KKK is not necessarily so, because it was a strictly US organization not well known outside. For example, there was a supermarket chain with KKK stores here in Finland: the chain is still called the "K-group", and back then they had single-K, double-K, and triple-K markets, increasing in size and stock. The chain was pretty horrified when they realized the double meaning, and quickly changed the naming scheme, even though it cost
a lot across the entire chain.
So, no absolutely fixed rule will work that well. The best solution is for the moderators or Dave to either change the username, lock the thread, or PM the user to inform about the issue, and see how they respond. My own communications errors are such that I definitely hope I get that PM first, because I'm not here to tout my opinions, just to learn and help others.
