Author Topic: ATMEL PLD device definition file  (Read 497 times)
Offline nipanchal72Topic starter
« on: March 21, 2025, 03:07:39 pm »
I am working with an old ATMEL PLD (ATF2500C-20KM) and trying to compile the original ABEL code using ABEL4.0 compiler. During compilation it flags an error "cannot find p2500c.dev file" (part definition file). This file reside within ABEL4.0 application in sub directory <LIB> ABEL4LIB.DEV or ABELPLD.DEV file. Is there a way to maually generate this file and once created how do I point to this device definition when compiling. Any suggestion would be helpful.
