Author Topic: How to waterproof your electronics  (Read 17655 times)
Offline TriplePointDesignTopic starter
« on: March 22, 2023, 07:38:30 pm »
This blog post is a summary of the many waterproofing methods we've used over the years in our open source logger project including the DIY underwater housings we make from PVC plumbing. Also describes how to oil-mount pressure sensors to protect them from salt water corrosion:
https://thecavepearlproject.org/2023/03/17/waterproofing-your-electronics-project/
The following users thanked this post: laneboysrc, Ian.M, luudee, Kim Christensen, redkitedesign, meshtron
Offline aeberbach
Re: How to waterproof your electronics
« Reply #1 on: March 22, 2023, 10:35:56 pm »
Thanks! I am hoping to get a network of soil moisture sensors in this year, it will be very useful to read this.
Software guy studying B.Eng.
« Reply #2 on: March 24, 2023, 07:20:30 pm »
We did a big student project last year with soil sensors that I should get around to posting about. Fair word of warning: getting soil data that is 'qualitatively understandable' when you glance a the graph is really quite easy. Getting soil moisture data that is quantitative is really darned hard. Relative to something like light sensors, calibration is more difficult because soil environments are so incredibly diverse.
« Reply #3 on: May 26, 2023, 06:52:20 pm »
After waterproofing, you need some way to test if it really worked right? We needed a way to test our little falcon tube loggers and household water filter housings are a good solution as the domestic water pressure range of 40-80psi overlaps nicely with sport diving depths. The internal clearance of that 4x10 filter housing is only slightly larger than 4.5" x 9.5" but could accommodate a good range of other dive computers, lights, etc for testing.
https://thecavepearlproject.org/2023/05/24/a-diy-pressure-chamber-to-test-housings/
Offline barshatriplee
  • Country: bd
« Reply #4 on: June 04, 2023, 10:29:41 am »
In this article, I can see a picture of a capacitive soil moisture sensor. I can see that it has been waterproofed by hot glue. But from the picture, it seemed to me that hot glue has covered not only the circuit but the electrode also. If the electrode is covered, how will it take reading from the soil? Isn't it supposed to touch the soil? Or there is no glue over the electrode?
Offline f4eru
    • Chargehanger
« Reply #5 on: June 14, 2023, 09:40:39 pm »
Capacitance sensors are insulated by principle.
Offline MathWizard
« Reply #6 on: April 02, 2025, 07:59:41 am »
Great article, I'll have to try potting something with hot-glue. There's a few outdoor projects I might make someday, like barn door alarms on a farm. I'll have to remember the superglue plus baking soda too, as a waterproof sealer in a jam, and plumber's putty. All easy and cheap to get.
« Last Edit: April 02, 2025, 08:17:36 am by MathWizard »
