Author Topic: Differencial probe 10x 1MHz using as8066  (Read 5888 times)
Offline Apollo1234Topic starter
  • Country: pt
« on: January 26, 2024, 04:58:11 pm »
Hy there.
Recently i got challenged to build a differencial probe with 10x attenuation, 1MHz BW using a low cost op amp. I alreay unerstood the attenuator but im still stuggling with the op amp feedback compensation, i read some articles but cant quite understand what im doing wrong, can someone pls help me and explain what is going on? the hase goes like crazy and cant understand where is the problem
Offline Simon
  • Global Moderator
    • Simon's Electronics
