Author Topic: NGen - A low cost programmable four channel engine speed simulator  (Read 2137 times)
Online 0xdeadbeef
It's bit of "special interest" and the hardware part is not too exciting, yet it's what I worked on for the last two years (with major gaps of course) or so in my spare time.
http://lemmini.de/NGen/NGen.html
Today I finally pushed everything in the repository, so I can hopefully continue with something else soon
https://bitbucket.org/fade0ff/ngen
jucole
  • Guest
Re: NGen - A low cost programmable four channel engine speed simulator
« Reply #1 on: April 18, 2014, 06:28:11 pm »
Looks like an very interesting project!     At the moment I'm actually working on a mini ECU reader of the various sensors etc but the RPM signal is from a VR sensor rather than a hall sensor;   but I can completely understand why you made this!  whilst working on my project I wished I had a complete engine simulation board as it would make the whole job a lot easier! ;-)
Online 0xdeadbeef
« Reply #2 on: April 18, 2014, 06:47:39 pm »
Like 10 years ago or so, I also worked on engine control units with inductive crank sensors. It's however not so difficult to get that kind of signal from a 5V signal. Yo don't actually need the sine form, just the shape of the gap has to be adapted (symmetric transition in the gap) and you need a bipolar signal. When I was lazy, I just used a max232 to convert the (inverted) 5V signal to a +/-9V volt signal.
